I've been looking through forums for an hour and cannot find the Layout Panel to save blocks in a drawing. Below is a screenshot of the panels available to me which does not include that option. Where/how do I put the Layout Panel into the Sketch Tab of a drawing??
I just checked and although I can create a block in an Inventor sketch it is only when I am creating a Part. I do not have the ability to create one in an actual part drawing. I need this to be in an actual drawing so I can easily drop in wiring parts or connectors that don't over complicate a wiring diagram or have to hide lines in a part if I simply drop a connector into the wiring diagram. Is there no way to create a block in an Inventor drawing?
I'm in 2017 and I do not see an option in the drawing enviroment.
Maybe you can use "Symbols" as a work around?
