Mate edges using using I-logic
4 REPLIES 4
508 Views, 4 Replies
I'm trying to mate two edges of two different cuboids in Inventor, I've named the edges manually, but now I'm trying to mate them using the I-logic code but the assembly is not fetching the edge name. It says "there is no such feature as Edge 1 in cuboid-1". I'm using the following code:-
Constraints.AddMate("Face_Mate_1", "Cuboid_1", "Edge 1", "Cuboid_2", "Edge 13",
 offset := 0.0, e1InferredType := InferredTypeEnum.kNoInference, e2InferredType := InferredTypeEnum.kNoInference,
 solutionType := MateConstraintSolutionTypeEnum.kOpposedSolutionType,
 biasPoint1 := Nothing, biasPoint2 := Nothing)
@Jon.Balgley
4 REPLIES 4
FINET_Laurent
Morning,
This should be a syntax issue. Make sure you respect capital letters and spaces (Part names in the assembly & edges names) ..
Could you provide files ?  (make sure it's not confidential)
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
in reply to: FINET_Laurent
So I was trying to convert this I-logic code for face naming for an assembly in inventor , I'm attatching the code below:
Face oFace1 = (Inventor.Face)Part1.ComponentDefinition.WorkSurfaces["Face 1"];
Face oFace2 = (Inventor.Face)Part2.ComponentDefinition.WorkSurfaces["Face 7"];
FaceProxy oAsmFace1, oAsmFace2;
object obj1;
occ1.CreateGeometryProxy(oFace1, out (obj1));
object obj2;
occ2.CreateGeometryProxy(oFace2, out (obj2));
oAsmFace1 = (FaceProxy)obj1;
oAsmFace2 = (FaceProxy)obj2;
oAssDoc.ComponentDefinition.Constraints.AddMateConstraint(oAsmFace1, oAsmFace2, 0);
FINET_Laurent
Morning,
Is this a question ? I'm not sure to understand.
FINET L.
Morning Laurent, So basically I was trying to convert an I-logic code into C#(C-sharp)...the code was regarding the process of mating with face naming using inventor, the code that I've sent you is my attempt to convert that I-logic code into C#.
@FINET_Laurent
Technology Administrators
