I'm struggling to get the converted geometries from a text box to get added to the selection.
i picked up the rule from another thread.
if i comment out line 69 to 73, the rule works.
Ideally i'd also like to just use the <Part number> iproperty in the text box rather than create a custom property.
Sub Main() 'This Is a Ilogic Rule To create a Mark From a textbox For engraving ' a reference to the currently active document. ' This assumes that it is a part document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oCompDef As PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Set a reference to the transient geometry object. Dim oTransGeom As TransientGeometry oTransGeom = ThisApplication.TransientGeometry '================ Pasted to pick the face where the Mark has to come ============================ 'Select Face and Edges to dimension sketch circles from Dim oFrontFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Text On") '============================================================ ' Create a new sketch on this face oSketch = oCompDef.Sketches.AddWithOrientation(oFrontFace, _ oCompDef.WorkAxes.Item(1), True, True, oCompDef.WorkPoints(1)) ' Determine where in sketch space the point (0.5,0.5,0) is. Dim oCorner As Point2d oCorner = oSketch.ModelToSketchSpace(oTransGeom.CreatePoint(0.5, 0.5, 0)) ' ===================== Create a Custom Parameter in Iproperties "Tekeningnummer"====================== 'Creating Custom IProperty with filenumber in it calling it Tekeningnummer iProperties.Value("Custom", "Tekeningnummer") = ThisDoc.FileName(False) 'false = without extension iProperties.Value("Custom", "Tekeningnummer") = (Left(ThisDoc.FileName(False),14)) 'Creating a UserParameter Where the Tekeningnummer value Is put In Dim PropValue As String = iProperties.Value("Custom", "Tekeningnummer") 'updates the user-defined Text Parameter TagName = PropValue '================================ Create a textbox in the Sketch to place the Iporp Tekeningnummer ==================== ' Create Text With simple String As Input. Since this doesn't use ' any Text Overrides, it will Default To the active Text Style. Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim sText As String sText = TagName Dim oTextBox As TextBox oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.5, 1), sText) '==================== Creating an Objectcollection to be Marked ====================== Dim oSketchObjects As ObjectCollection oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection ' Get all entities In the sketch Dim oEntities As Object 'Dim oSketchText As TextBox oTextBox.ConvertToGeometry("ISO") For Each oEntities In oSketch.SketchEntities oSketchObjects.Add(oEntities) Next For Each oSketchText In oSketch.TextBoxes oSketchObjects.Add(oSketchText) Next ' Dim oSketchEntity As Object 'For Each oSketchEntity In oTransientGeometry ' oSketchObjects.Add(oTransientGeometry) 'Next '==================== Creating the Mark on the textbox ====================== Dim oMarkFeatures As MarkFeatures oMarkFeatures = oCompDef.Features.MarkFeatures ' Get a mark style. Dim oMarkStyle As MarkStyle oMarkStyle = oPartDoc.MarkStyles.Item(1) ' Create mark definition. Dim oMarkDef As MarkDefinition oMarkDef = oMarkFeatures.CreateMarkDefinition(oSketchObjects, oMarkStyle) ' Create a mark feature. Dim oMark As MarkFeature 'oTextBox.ConvertToGeometry("ISO") oMark = oMarkFeatures.Add(oMarkDef) '==================== End Sub
Hi @romu51
Can you explain where you would like assistance?
You comment out line 69 to 73 can you explain where that is? There is no numbers in the code block you pasted. In order to show the numbers you need to use the dedicated editor in the posting toolbar which can found with button </> , if these lines are not required you can remove them. I am assuming there are the mark feature lines and you are using an older version of inventor.
For the partnumber you can just remove the custom iproperty lines.
On this line set the text to the part number iproperty.
sText = iProperties.Value("Project", "Part Number")
If you have any other issues please share the modified code and any errors your seeing using the more info tab of the error message box.
Thanks for the reply.
See below for a tidied up version of the rule.
Sub Main() 'This Is a Ilogic Rule To create a Mark From a textbox For engraving a reference to the currently active document. ' This assumes that it is a part document. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oCompDef As PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition ' Set a reference to the transient geometry object. Dim oTransGeom As TransientGeometry oTransGeom = ThisApplication.TransientGeometry '================ Pasted to pick the face where the Mark has to come ============================ 'Select Face and Edges to dimension sketch circles from Dim oFrontFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to Place Text On") ' Create a new sketch on this face oSketch = oCompDef.Sketches.AddWithOrientation(oFrontFace, _ oCompDef.WorkAxes.Item(1), True, True, oCompDef.WorkPoints(1)) ' Determine where in sketch space the point (0.5,0.5,0) is. Dim oCorner As Point2d oCorner = oSketch.ModelToSketchSpace(oTransGeom.CreatePoint(0.5, 0.5, 0)) ' Create Text With simple String As Input. Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim sText As String sText = iProperties.Value("Project", "Part Number") Dim oTextBox As Inventor.TextBox oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(0.5, 1), sText) oTextBox.FormattedText = "<StyleOverride FontSize = '0.5'>" & sText & "</StyleOverride>" oTextBox.ConvertToGeometry("ISO") ' ' Start the feature command ThisApplication.CommandManager.ControlDefinitions.Item("PartMarkingCmd").Execute() End Sub
At the end, I'm executing the command to keep me going but ideally the MarkFeature should pickup the converted geometries and be ok.
Edit: I'm on AIV 2023.3
