make BOM inseparable with ilogic and custom property
5 REPLIES 5
morrenengineering
306 Views, 5 Replies
My assembly ' s are labelled with a custom property, called "art", which means article. For some lists, the welding must be inseparable. I made for this an ilogic rule, but it works, but it becomes not inseparable. I thick it is some small, can someone help me?
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the referenced models
For Each oRefDoc In oRefDocs
	Dim oCurFile As Document
	oCurFile = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
	Dim art1 As Inventor.Property
	art1 = Nothing
    	Try
			art1 = iProperties.Value("Custom", "art")
		    If art1 = "WEL" Then
			oCurFile.ComponentDefinition.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
			End If
    	Catch
        	'MessageBox.Show("Error processing " & oCurFileName, "ilogic")
    	End Try
	oCurFile.Close
	Next
5 REPLIES 5
Hello. If I understood you correctly, then this should help you:)
Dim oDoc As Document = ThisApplication.ActiveDocument
If TypeOf oDoc Is AssemblyDocument Then
	Dim oAssDoc As AssemblyDocument = oDoc
	For Each oRefDoc As Document In oAssDoc.ReferencedDocuments
		If TypeOf oRefDoc Is AssemblyDocument Then
			For Each art As Inventor.Property In oRefDoc.PropertySets.Item("Inventor User Defined Properties")
				If art.Value = "WEL" Then
					oRefDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
					oRefDoc.SubType = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}"
				End If
			Next
		End If
	Next
End If
Andrii Humeniuk - Leading design engineer
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Hello, it does give an error (in dutch):
Error on line 7 in rule: BOM-inseperatable, in document: C111.iam
De conversie van tekenreeks WEL naar type Double is ongeldig.
I had an old code, it works, but I would that it would nog depends on the filename, but on the "art" custom field.
The old code is attached.
Hello. Please try this:
			For Each oProp As Inventor.Property In oRefDoc.PropertySets.Item("Inventor User Defined Properties")
				If oProp.Name = "art" And oProp.Value = "WEL" Then
					If oRefDoc.ComponentDefinition.BOMStructure <> BOMStructureEnum.kInseparableBOMStructure Then
					End If
				End If
			Next
		End If
	Next
End If
Hi Andrii,
I can't accept your solution because there was a small mistake in it. Oprop.value had to become oprop.expression. Anyway, thank you very much for this great code and good help.
				If oProp.Name = "art" And oProp.Expression = "WEL" Then
					End If
				End If
			Next
		End If
	Next
End If
I've been working with the code for a day now, but it still doesn't do what I expected. He only changes it at the current level and not a level deeper. My first option did. Is that a simple line in the program?
Technology Administrators
