Hi!
I can't figure out how to solve this problem with iLogic.
I have a multi body part and I want to make an assembly using make components. Name of the new parts in the assembly should consist of, Description from iProperties and name of the bodies.
New assembly name must be the same as the original part.
Thank you!
Solved by gerrardhickson. Go to Solution.
Hi Mecanicu,
Do you want help writing the code, or do you just want someone to do it for you?
Here's a very simple framework that might help:
Dim oMultiPart As PartDocument = ThisApplication.ActiveDocument
Dim oMCD As ComponentDefinition = oMultiPart.ComponentDefinition
Dim oBody As SurfaceBody
Dim sBodyNames As String
'Create new Assembly
For Each oBody In oMCD.SurfaceBodies
sBodyNames = sBodyNames & vbCrLf & oBody.Name
'Create new Part file
'Derive Part with reference to oBody
'Add the body to the assembly - ground and root component
Next oBody
MessageBox.Show (sBodyNames)
The code itself only builds a list of the surface bodies, and shows you the list at the end - nothing else. But the purpose of the code is to show you how you might want to break the problem up into small steps. Each of the small steps isn't complex, so give it a try and report back with your progress.
Yesterday i have a non working version of the code. Now after some brain storming i manage to get it to work. But i still have some problem's. the main one is the part naming, now it's using the solid body's name. Here is the version i have:
' Run this inside a Multi-Solid part
Sub Main()
' Folder to place the new components:
' assembly and subcomponents
Dim f As String
f = "C:\temp\test1\"
Dim oTemplatesPath As String
oTemplatesPath = "C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates\en-US"
' Make sure the folder exists
Dim fso As Object
fso = ThisApplication.FileManager.FileSystemObject
If Not fso.FolderExists(f) Then Call fso.CreateFolder(f)
Dim doc As PartDocument
doc = ThisApplication.ActiveDocument
' Create the assembly
Dim asm As AssemblyDocument
asm = ThisApplication.Documents.Add(kAssemblyDocumentObject, oTemplatesPath & "\SheetMetalDXF.iam", True)
Dim sb As SurfaceBody
For Each sb In doc.ComponentDefinition.SurfaceBodies
' See if the body is visible
If sb.Visible Then
' Create part for each body
Dim prt As PartDocument
prt = ThisApplication.Documents.Add(kPartDocumentObject, oTemplatesPath & "\Sheet Metal.ipt", True)
' Set iProperties >> Project >> Description
' It's inside "Design Tracking Properties"
Dim p As String
p = "lol" 'prt.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Description") !!!!!
p = sb.Name
Dim dpcs As DerivedPartComponents
dpcs = prt.ComponentDefinition.ReferenceComponents.DerivedPartComponents
Dim dpd As DerivedPartUniformScaleDef
dpd = dpcs.CreateUniformScaleDef(doc.FullDocumentName)
' Exclude the other solid bodies
Dim dpe As DerivedPartEntity
For Each dpe In dpd.Solids
If Not dpe.ReferencedEntity Is sb Then
dpe.IncludeEntity = False
End If
Next
dpcs.Add(dpd)
' Could have any name but we use the solid body's name
' !!!!!The final name needs to be part description + solid body's name!!!!!
prt.SaveAs(f + sb.Name + ".ipt", False)
' Place an instance of it inside the assembly
Dim mx As Matrix
mx = ThisApplication.TransientGeometry.CreateMatrix()
asm.ComponentDefinition.Occurrences.AddByComponentDefinition(prt.ComponentDefinition, mx)
' Don't need it anymore
prt.Close
End If
Next
asm.SaveAs(f + Left(doc.DisplayName, Len(doc.DisplayName) - 4) + ".iam", False)
asm.Close
End Sub
Well you were very close to a solution.
Here's a working solution.
You'll need to change all the file\folder paths to suit your setup.
I'm sure y
Sub Main()
Dim f As String
f = "F:\Vault\Design Files\_Temp\5. SaveMultiBodyAsAssembly\"
oTemplatesPath = "F:\Vault\Design Files\_Admin\Templates"
Dim fso As Object
asm = ThisApplication.Documents.Add(kAssemblyDocumentObject, oTemplatesPath & "\Assembly.iam", True)
If sb.Visible Then
prt = ThisApplication.Documents.Add(kPartDocumentObject, oTemplatesPath & "\Standard Part.ipt", True)
Dim p As String
'MessageBox.Show(doc.PropertySets("Design Tracking Properties")("Description").Value)
p = doc.PropertySets("Design Tracking Properties")("Description").value
p = p & " - " & sb.Name
'messagebox.Show(doc.FullDocumentName)
End If
Next
dpcs.Add(dpd)
prt.SaveAs(f + " - " + p + ".ipt", False)
Dim mx As Matrix
prt.Close
End If
Next
asm.SaveAs(f + doc.displayname.replace(".ipt",".iam"), False)
asm.Close
End Sub
Thank you @gerrardhickson!
I modify the first version for Multi Body Sheet Metal Part, it's not perfect, i have some problem with parsing Sheet Metal Style to new part's. And i wish to make it External Rule, for now it's only working from part level. + i include a DXF export function also.
' Run this inside a Multi-Solid part; Custom for Multi-Solid Sheet Metal Part
Sub Main()
' Determine master part type '''' here is a test code to store the active sheet metal style and past it to new part's '''
Dim doc As PartDocument = ThisApplication.ActiveDocument
If doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim oDocSheetMetalCompDef As SheetMetalComponentDefinition = doc.ComponentDefinition
Dim oDocSheetMetalStyle As SheetMetalStyle = oDocSheetMetalCompDef.ActiveSheetMetalStyle
oDocSheetMetalStyle.SaveToGlobal
End If
' Same Folder as Master Part to place the new components:
Dim f As String
f = ThisDoc.Path & "\"
' Templates Folder
' Make Folder for DFX export !!! folder name is master part name & DXF File
Dim oFolder As String = f & doc.DisplayName.Replace(".ipt", " DXF File")
Dim fso As Object
If Not fso.FolderExists(oFolder) Then fso.CreateFolder(oFolder)
' Create the assembly, select assembly template
' Iterate through solid bodies
' See if the solid body is visible
If sb.Visible Then
' Create new part for each solid body, , select part template
' Store solid body name
Dim p As String
p = sb.Name
' Set new part display name !!! Not the same as new part file name
prt.DisplayName = p
' Derived solid body
End If
Next
' Export derived solid body
dpcs.Add(dpd)
' Determine new part type
If prt.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
prt = ThisApplication.ActiveDocument
' Copy and activate sheet metal style from master part to new part, unfold the new part
Dim oPrtSheetMetalCompDef As SheetMetalComponentDefinition = prt.ComponentDefinition
oPrtSheetMetalCompDef.SheetMetalStyles.Item("Tabla 1mm").Copy("Tabla 1mm") 'don't know how to read the master part active sheet metal style name si i cand use it
oPrtSheetMetalCompDef.SheetMetalStyles.Item("Tabla 1mm").Activate()
oPrtSheetMetalCompDef.Unfold()
' Custom DXF Flat Pattern settings, here u can edit them '
Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=Burn&InteriorProfilesLayer=Burn&FeatureProfilesDownLayerColor=0;128;255&FeatureProfilesUpLayerColor=255;0;0&InvisibleLayers=IV_UNCONSUMEND_SKETCHES;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_ARC_CENTERS;IV_TOOL_CENTER_DOWN;IV_TOOL_CENTER;IV_ARC_CENTERS;IV_TANGENT;IV_BEND;IV_BEND_DOWN&SplineTolerance Double 0.001&MergeProfilesIntoPolyline=True"
' DXF file name, export DXF, exit Flat Pattern
Dim DxfName As String = sb.Name & ".dxf"
oPrtSheetMetalCompDef.DataIO.WriteDataToFile(sOut, oFolder & "\" & DxfName)
oPrtSheetMetalCompDef.FlatPattern.ExitEdit()
End If
' Save new part !!! Name is master part name + solid bodies name
prt.SaveAs(f + doc.DisplayName.Replace(".ipt", " ") + sb.Name + ".ipt", False)
Dim mx As Matrix
prt.Close
End If
Next
' Save assembly and close it !!! Same name as master part
asm.SaveAs(f + doc.DisplayName.Replace(".ipt", ".iam"), False)
asm.Close
End Sub
Ok - I haven't looked into it too deeply, but I think I see the problem.
It seems that you're intending to 'copy' the sheet metal style from the parent assembly to the new part. That doesn't work. Keep in mind that you're using code to replicate the process that you would take manually - and that process is to export the style to an .xml file, and then import it to your new part. Practically speaking, this is a little clunky, a better approach is to add the style to your template file manually before the (assuming that you only have a few styles to work with).
Finally, once your style is loaded into the template file, just activate it with the line below, as you're already doing.
Hope that helps.
I manage to resolve the sheet metal style problem. Now it's working as external rule as well. Here is the final code:
Sub Main()
' Determine master part type, store sheet metal style name and save style to global
Dim styleName As String
styleName = oDocSheetMetalStyle.Name
oDocSheetMetalStyle.SaveToGlobal()
End If
Dim f As String
' Templates Folder
Dim fso As Object
If sb.Visible Then
Dim p As String
p = sb.Name
prt.DisplayName = p
End If
Next
dpcs.Add(dpd)
' Activate sheet metal style from master part to new part, unfold the new part
oPrtSheetMetalCompDef.SheetMetalStyles.Item(styleName).Activate()
End If
Dim mx As Matrix
prt.Close
End If
Next
asm.Close
End Sub
Dear Mecanicu,
The rule you created works well for my intentions which is to create an assy from a multi-bodied part, but does it also happen to you that patterned or mirrored parts don't have the solid included in the derived part?
All the other parts have a small green arrow in the derived part browser but my mirrored part does not.
Please find attached a screenshot of the derived part browser and the modded code.
Here is your code that I have modified to see if it can serve my needs.
