Macro Help: Macro to Open file from Excel BOM
4 REPLIES 4
ablountE9KSN
214 Views, 4 Replies
So the intended purpose of the macro is to select the file name from the excel BOM - and then run the macro - the macro would then open the file in inventor. The code is running in excel vba from my exported BOM.
This is my code
Sub OpenDrawing()
    Dim FileLocation As String
    FileLocation = Range("C4")
    Dim FileName As String
    FileName = ActiveCell.Value
    Dim FullFileDirectory As String
    FullFileDirectory = FileLocation & "\" & FileName
    Dim InvApp As Inventor.Application
    Set InvApp = CreateObject("Inventor.Application")
    Dim Doc As Inventor.Document
    Set Doc = InvApp.Documents.Open(FullFileDirectory, True)
End Sub
Im getting an error on the "Set Doc" line "Run time error '5: Invalid Call Procedure or argument"
I'm new to vba so any help is appreciated
4 REPLIES 4
A.Acheson
in reply to: ablountE9KSN
Hi @ablountE9KSN
Can you check you fullfilepath has an extension .ipt or .iam and or copy and paste to windows and launch to verify?
Regards
Alan
ablountE9KSN
that was it - I ended up adding a file extension to the FullFileDirectory string and it worked perfectly.
m_scottW4DSR
@A.Acheson
I am running this code and it executes without error.  But nothing is happening with the inventor application. I have run with and without an open inventor session.  Any idea of the issue?  I'm guessing something not configured properly with inventor?
Thanks!
m_scottW4DSR
in reply to: m_scottW4DSR
Added
oInvApp.Visible = True
and all is well.
Not sure why
Set oDoc = oInvApp.Documents.Open(sfilename, True)
didn't take care of it
Technology Administrators
