Loop Through all sheets, delete revision rows, delete revision block. problem
pschell
pschell
Hello all,
I have a bit of code that i created with Inventor 2016. We recently updated to Inventor 2018 and now my code is not working properly. I have tried figuring out how to fix the problem and I'm stumped.
Sub Main RemoveAllTags()
	Dim oDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
	Dim i As Integer = 1
	Dim oRTB As RevisionTable = oDrawDoc.ActiveSheet.RevisionTables.Item(i)
	Dim oRow As RevisionTableRow
	Dim oSheet As Sheet
	For Each oSheet In oDrawDoc.Sheets
		oSheet.Activate
		oSheet.Update
		Try	'try to get the first rev table on the active sheet
			oRTB = oDrawDoc.ActiveSheet.RevisionTables.Item(i)
		Catch 'catch error when no rev table is found
			MessageBox.Show("Error: No Revision Table was found", "iLogic")
		End Try
		Dim oRows As RevisionTableRows
		oRows.Add()
		For Each oRow In oRows
			If oRow.IsActiveRow Then
			Else
				oRow.Delete
			End If
		Next
		oRTB.Delete
	Next
End Sub
 This is my original code snippet that has ceased to work. I have done some troubleshooting on it and have found that it breaks on "oRows.add()". If anyone can help me on this I would greatly appreciate it. Attached is the Error in Rule that pops up when i run the code.
thanks
pschell
Nevermind. I fixed it. :
	Dim oSheet As Sheet
		oSheet.Activate
		oSheet.Update
		End Try
		Dim oRows As RevisionTableRows = oRTB.RevisionTableRows
		oRows.Add()
			Else
				oRow.Delete
			End If
		Next
		oRTB.Delete
	Next
End Sub
If anyone is looking for ilogic code to iterate through all sheets, to delete revision tags and revision blocks ... then this works. thanks
pschell
On further testing of my code, every time I had a sheet with no revision table I would get an error.
I have modified my previous code extensively to produce this:
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
		oSheet.activate
		ProcessSheet(oSheet)
	Next
	oDrawDoc.Update
End Sub
Sub ProcessSheet(oSheet As Sheet)
	If oSheet.RevisionTables.Count = 0 Then
		On Error Resume Next
	End If
	Dim oRTB As RevisionTable = oSheet.RevisionTables.Item(1)
	oRows.Add()
	Dim oRow As RevisionTableRow = oRTB.RevisionTableRows.Item(oRTB.RevisionTableRows.Count)
		Else
			oRow.Delete
		End If
	Next
	oRTB.Delete
End Sub
Now there are no errors and this works every time.
Hope this helps someone else out there.
G.Binl
Thanks for the Code it worked great,
I add some code to it hop you or someone else can use it.
it just places the Table where you wanted.
Next
oRTB.Delete
oDrawDoc = ThisApplication.ActiveDocument
Dim oRTBs As RevisionTables
oRTBs = oDrawDoc.ActiveSheet.RevisionTables
Dim oLocation As Point2d
oLocation = ThisApplication.TransientGeometry.CreatePoint2d(68.08999997, 9.780835)
oRTB = oRTBs.Add(oLocation)
End Sub
Jusdoo
I have developed an app to operate revision tables. For trial version, it just limits the time and number of sheets to use. hope it will help.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=7788639131627009214&appLang=en&os=Win64
