Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Linking Drawing Template to other document types such as Word & Excel.
11 REPLIES 11
Message 1 of 12
patrickJ7ELM
542 Views, 11 Replies
patrickJ7ELM
I'm wondering if it's possible to pull text/data from other documents and into Drawing Templates.
Example:
I have a drawing for a pipe and i want to pull data from a WPS (Welding procedure Specification). Lets say this document gets created by a different person but always in the same path as the output drawing. is it possible to create a dedicated field in the WPS, which again can be pulled into the dwg?
I would like it to show as source in "Format text" dialog.
i have no clue on where to begin on this and i would appreciate any inputs ๐Ÿ™‚
Example:
Labels (6)
11 REPLIES 11
Message 2 of 12
patrickJ7ELM
in reply to: patrickJ7ELM
patrickJ7ELM
Update.
I'm able to extract information to a custom Iproperty and then use it on the sheet. the text does not display for some reason. and im not sure how i will make the path change for different documents.
GoExcel.Open("C:\Users\Patrick\OneDrive - Rรธrtek As\Desktop\TEST-WPS.xlsx", "Ark1")
iProperties.Value("User Defined Properties", "Standard") = GoExcel.CellValue("A3")
iLogicVb.UpdateWhenDone = True
The iproperties does get information from excel sheet here.
but this plot does not work.
Update.
Message 3 of 12
patrickJ7ELM
patrickJ7ELM
this works now. but i need to be able to change Reference excel document.
Message 4 of 12
tyler.warner
tyler.warner
Would it work for you to just add another custom iProperty that specifies the source?
For both of these examples, you would just create that additional custom iProperty called "StandardSource".
This example you would change the property to be the title of the source file.
StandardSource = TEST-WPS.xlsx
GoExcel.Open("C:\Users\Patrick\OneDrive - Rรธrtek As\Desktop\" & iProperties.Value("User Defined Properties", "StandardSource"), "Ark1")
This example you would change the property to be the full path & title of the source file.
StandardSource = C:\Users\Patrick\OneDrive - Rรธrtek As\Desktop\TEST-WPS.xlsx
GoExcel.Open(iProperties.Value("User Defined Properties", "StandardSource"), "Sheet1")
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Message 5 of 12
patrickJ7ELM
in reply to: tyler.warner
patrickJ7ELM
This is better than what i had. But i want it for look for documents in the same folder as drawings. so that as long as there is a WPS-XXX.xlsx file in that folder it will use the one that is available. i dont know what will happen if there ar two different files though.
to be honest, im just experimenting and trying to find ways for improvement. if you have any other ilogic/VB tips for drafts i would much appreciate.
Thanks in advance ๐Ÿ™‚
Message 6 of 12
A.Acheson
A.Acheson
If you supply the filename and extension then go excel will search the directory of the document  you launched the rule from.
GoExcel.Open("TEST-WPS.xlsx")
Or alternatively use ilogic function ThisDoc.Path and filename.
GoExcel.Open(ThisDoc.Path & "\TEST-WPS.xlsx)
If this solved a problem, please click (accept) as solution.โ€Œโ€Œโ€Œโ€Œ
Or if this helped you, please, click (like)โ€Œโ€Œ
Regards
Alan
Regards
Alan
Message 7 of 12
tyler.warner
tyler.warner
You can try something like this that will search the folder of the current document for a file that has "WPS" & ".xlsx" & then opens that one.
Dim oPath As String = ThisDoc.Path & "\"
Dim oFiles As String() = System.IO.Directory.GetFiles(oPath)
For Each oFile In oFiles
	If oFile.Contains("WPS") And oFile.Contains(".xlsx")
		GoExcel.Open(oFile, "Ark1")
		Exit For
	End If
Next
		Exit For
	End If
Next
Message 8 of 12
patrickJ7ELM
patrickJ7ELM
This is close to what i want. i am just experimenting as previously stated. but i will get a problem with multiple files named WPS.xlsx, right?
Thanks alot for your help ๐Ÿ™‚
Message 9 of 12
tyler.warner
tyler.warner
It will just go with the first file that it finds which fits the search criteria. You can add a prompt or something if you want to do a check.
Message 10 of 12
patrickJ7ELM
patrickJ7ELM
Any suggestion to how that prompt would look?
Message 11 of 12
tyler.warner
tyler.warner
You could do something like this with a basic message box if you want user interaction.
		Dim oResult = MessageBox.Show("Is this the correct file?" & vbNewLine & oFile, "File Selection", MessageBoxButtons.YesNo)
		If oResult = DialogResult.Yes
			Exit For
		End If
	End If
Next
			Exit For
		End If
	End If
Next
Message 12 of 12
patrickJ7ELM
patrickJ7ELM
Good job, i can see there are many possibilities to achieve my goal.
thanks alot, i'll try to be more active on ilogic/vba as this is a very interesting subject.
