Is there a way to link some of the iProperty text to another iProperty text. Eg. end of Partnumber, to end of Description?
If I Copy a part, the Partnumber changes, but I also want the description to change to the same.
Thanks in advance
Solved by JelteDeJong. Go to Solution.
You could try something like this: If you run this rule it will find the part after the _ and add/exchange it with the part after the _ in the description.
Dim partnumber As String = iProperties.Value("Project", "Part Number")
Dim parts = partnumber.Split("_")
Dim lastPart = parts(parts.Count() -1)
Dim oldDescription As String = iProperties.Value("Project", "Description")
Dim descriptionParts = oldDescription.Split("_")
Dim descriptionFirstPart = descriptionParts(0)
Dim newDescription = String.Format("{0}_{1}",descriptionFirstPart,lastPart)
iProperties.Value("Project", "Description") = newDescription
You could run this rule on save or something like that.
Jelte de Jong
Blog: hjalte.nl - github.com
I only have one small issue.
I have trickered it to run after save.
When I save an assembly it puts "_" after all files.
Is it possible to change the code, so if there's no "_" after the file, it should be left as it is?
Again thank you 😊
