Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
lines and shading don't match while rescaling
2 REPLIES 2
154 Views, 2 Replies
I use ole automation from delphi to automate drawings.
The delphi program changes parameters in the ipt and then updates the idw.
This works fine but in the final step I change DrawingView.Scale. Then the shading and the lines are scaled differently (see attachment).
Code:
DrawingView.Scale := 0.200;
DrawingDocument.Activate;
DrawingDocuent.Update;
for i := 1 to 100 do app.ProcessMessages();
When I put Inventor on the foreground then everything works correctly.
- Is there an other method than "Update" to update the drawingdocument?
- Is there a method to bring Inventor to the foreground?
I use Inventor 2008 SP2. With Inventor 10 I didn't have this problem.
2 REPLIES 2
Drawings require that they have focus in order for them to update correctly.
Even though this is being avoided as much as possible, some workflows such
as yours still require that the window have focus.
Try adding a call to AppActivate to bring Inventor to the foreground:
AppActivate(Application.Caption);
where Application is Inventor's Application object.
Sanjay-
Thanks Sanjay.
I already implemented your solution, although it isn't a very elegant one.
Technology Administrators
