Limited bend line - Ilogic
enrico.silva1
enrico.silva1
Hello, thanks for reading this post.
I am trying to export my sheet metals to DXF in order to cut on the CNC machine.
But, when export my sheet metal to DXF, the lines of bend are completed and I want to leave the bend line 15 mm apart from the base line of the piece. There is some command in Ilogic for this? Can someone help me?
See exemple in anex.
Many thanks
johnsonshiue
Hi! I don't believe there is an out-of-box solution to do that. The request is quite unique. Maybe you can tweak the bend line's linetype to have the similar behavior. But, I am not sure if there is a line type guarantee 15mm offset from the edge.
Many thanks!
Software Test Engineer
enrico.silva1
Okay my friend.
I gonna continue try do this.
Many thanks!
davis.j
I am also interested if anyone has preformed this in Inventor ilogic. The 3rd party app "DXF Exporter" can do it.
I use the following Ilogic routine but it would be nice to have it trim the bend lines too.
Sub Main()
On Error GoTo ErrorHandler
	oDoc = ThisDoc.Document
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
		If oCompDef.HasFlatPattern = False Then
			oCompDef.Unfold
		Else
			oCompDef.FlatPattern.Edit
		End If
		Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2010" _
			+ "&OuterProfileLayer=0" _
			+ "&OuterProfileLayerColor=0 ;0 ;0" _
			+ "&InteriorProfilesLayer=0" _
			+ "&InteriorProfilesLayerColor=0 ;0 ;0" _
			+ "&BendDownLayer=Scribe" _
			+ "&BendDownLayerLineType=37633" _
			+ "&BendDownLayerColor=0 ;0 ;255" _
			+ "&BendUpLayer=Scribe" _
			+ "&BendUpLayerLineType=37633" _
			+ "&BendUpLayerColor=0 ;0 ;255" _
			+ "&InvisibleLayers=IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN" _
			+ ";IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL;IV_TANGENT" _
			+ ";IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES" _
			+ "&RebaseGeometry=True" _
			+ "&SimplifySplines=True" _
			+ "&SplineTolerance=0.01" _
			+ "&MergeProfilesIntoPolyline=True"
		Dim oPath As String = ThisDoc.Path
		If oPath = String.Empty Then
			MsgBox("Please save your document first.", , "iLogic Export Flat Pattern")
			Exit Sub
		End If
		Dim sFname As String
		Dim sfd As New SaveFileDialog
		dName = ThisDoc.Document.DisplayName
		sName = Left(dName, Len(dName) - 4)
		sfd.Filter = "DXF Files (*.dxf)|*dxf"
		sfd.InitialDirectory = oPath
	'	sfd.FileName = iProperties.Value("Project", "Part Number")
		sfd.FileName = sName & ".dxf"
		If sfd.ShowDialog = System.Windows.Forms.DialogResult.OK Then
			sFname = sfd.FileName
			If Not Strings.Right(sFname, 4) = ".dxf" Then sFname = sFname & ".dxf"
		Else
			Exit Sub
		End If
	 	oCompDef.DataIO.WriteDataToFile(sOut, sFname)
		oCompDef.FlatPattern.ExitEdit
		MessageBox.Show("Your file was saved in the following directory: " + sFname)
	Else
		MessageBox.Show("Only sheet metal parts can be exported as DXF.")
	End If
Exit Sub
ErrorHandler:
	MessageBox.Show("The file is in use!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop, MessageBoxDefaultButton.Button1)
    Exit Sub
End Sub
