Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Laser Cut Length
3 REPLIES 3
alex_kalin
393 Views, 3 Replies
Laser Cut Length
l have found this iLogic code to calculate the Laser cut length for our sheetmetal parts. The code works perfectly at part level, l have the event trigger set to "before save document". But when l have the part in an assembly and click save for an updated part, it doesnt update saying the part must be 'active' for this rule to work.
Is there any line of code that l can add to be able to run this rule when l click "save" in the assembly.
If Not TypeOf ThisApplication.ActiveDocument Is PartDocument Then
        MsgBox("A Part document must be 'active' for this rule to work.  Exiting rule.",,"")
        Exit Sub
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
If Not TypeOf oPDoc.ComponentDefinition Is SheetMetalComponentDefinition Then
        MsgBox("This Part is not a Sheet Metal Part.  Exiting rule.",,"")
        Exit Sub
Dim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
If Not oSMDef.HasFlatPattern Then
        oAns = MsgBox("This Sheet Metal Part does not have a Flat Pattern." & vbCrLf & _
        "This is needed to calculate 'LaserCutLength'." & vbCrLf & _
        "Do you want this rule to automatically create the Flat Pattern, then continue?", vbYesNo + vbQuestion, "")
        If oAns = vbNo Then Exit Sub
               Try
                       oSMDef.Unfold
               Catch oEx As Exception
                       MsgBox("Failed to 'Unfold' this Sheet Metal Part, to create a Flat Pattern." & vbCrLf & _
                       oEx.Message & vbCrLf & oEx.StackTrace, , "")
                       Exit Sub
               End Try
Dim oFP As FlatPattern = oSMDef.FlatPattern
Dim oLengths As New List(Of Double)
For Each oEL As EdgeLoop In oFP.BottomFace.EdgeLoops
    oLengths.Add(ThisApplication.MeasureTools.GetLoopLength(oEL))
Next
'a = InputListBox("", oLengths, 0.0, "Loop Lengths", "Individual Loop Lengths")
Dim oParam As UserParameter
Try
        oParam = oSMDef.Parameters.UserParameters.Item("Cutting_Distance")
        oParam.Value = oLengths.Sum
Catch
        oParam = oSMDef.Parameters.UserParameters.AddByValue("Cutting_Distance", oLengths.Sum, "mm")
End Try
iLogicVb.UpdateWhenDone = True
Alex
3 REPLIES 3
matt_jlt
in reply to: alex_kalin
If you are using iLogic, this should fix your issue. You need to change it from ThisApplication.ActiveDocument to ThisDoc.Document.
The reasoning is that when you use ThisApplication.ActiveDocument. It is getting the current document that inventor has open / activated which is your assembly document. If you want to run it  on the document that the rule is stored in, you need to use ThisDoc.Document. As it doesnt matter what is calling up the rule, it will always get the document that is containing the rule.
Example
If Not TypeOf ThisDoc.Document Is PartDocument Then
        Exit Sub
Dim oPDoc As PartDocument = ThisDoc.Document
        Exit Sub
alex_kalin
in reply to: matt_jlt
Thanks for your response. lm not sure if it solves my problem though, because when l run click save and run in the ilogic rule it instantly pops up with a messag "a part document must be active for this rule to work. exiting rule"
So its actually got worse. This is how l have updated the rule
If Not TypeOf ThisDoc Is PartDocument Then
	Exit Sub
	Exit Sub
		Try
			oSMDef.Unfold
			Exit Sub
		End Try
Next
Try
Catch
End Try
alex_kalin
Removed the first portion of the code and the portion "This.Doc.Document.
Seems to be working okay now
'If Not TypeOf ThisApplication.ActiveDocument Is PartDocument Then
	'MsgBox("A Part document must be 'active' for this rule to work.  Exiting rule.",,"")
	'Exit Sub
'End If
Dim oDoc As PartDocument = ThisDoc.Document
If Not TypeOf oDoc.ComponentDefinition Is SheetMetalComponentDefinition Then
	Exit Sub
Dim oSMDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
		Try
			oSMDef.Unfold
			Exit Sub
		End Try
Next
Try
Catch
End Try
