Issues with programming functional YesNo message box - ilogic
Hello!
i'm trying to program a message box that activates a second rule if  "yes" i selected, and disregards the rule if "No" is selected. so far i have this, but no matter what button i press, it generates the PDF.. what exactly am i missing ?
SyntaxEditor Code Snippet
i = MessageBox.Show("Save current drawing as PDF?", "Save as", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
If vbYes Then iLogicVb.RunRule("auto pdf")
If vbno
End If
Mark.Lancaster
@Anonymous
When dealing with programming, iLogic for Inventor, you should be posting in the Inventor Customization forum for best results.  I will have the moderator relocate your posting there..
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
Mark Lancaster
GeorgK
Select Case MsgBox("Save current drawing as PDF?", vbYesNo, "Test")
Case vbYes
    ' Ja
Case vbNo
    ' Nein
End Select
