IsNumeric on Custom Property
3 REPLIES 3
M_Santi
147 Views, 3 Replies
Is there a way to make the custom property gauging required = "YES" if the value of custom property gauging cost contain a numerical value?
Thank you.
If iProperties.Value("CUSTOM", "GAUGING COST") = IsNumeric(aString) Then
iProperties.Value("CUSTOM", "GAUGING RERQUIRED") = "YES"
End If 'update all'
iLogicVb.UpdateWhenDone = True
3 REPLIES 3
WCrihfield
in reply to: M_Santi
Hi @M_Santi.  You can try it like this, and see if this works as you expect.
Dim oValue
Try 'because this is a 'custom' iProperty, it may not exist
	oValue = iProperties.Value("CUSTOM", "GAUGING COST")
Catch
	MsgBox("The custom iProperty named 'GAUGING COST' was not found.", vbCritical, "iLogic")
	Return
End Try
If oValue IsNot Nothing Then
		If IsNumeric(oValue) Then
		Else
			iProperties.Value("CUSTOM", "GAUGING RERQUIRED") = "NO"
		End If
	Catch
		MsgBox("The custom iProperty named 'GAUGING RERQUIRED' was not found.", vbCritical, "iLogic")
	End Try
End If
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
M_Santi
in reply to: WCrihfield
It works, but I have to manually run the rule to get the value of yes or no on "gauging required" when I input the value on "gauging cost". What do I need change to make it so that it runs the rule automatically every time I change the value on the "Gauging cost".
WCrihfield
Hi @M_Santi.  First, how was that custom iProperty created?  Manually, though the main iProperties dialog, on the Custom tab?  Or was it created automatically by marking a Parameter within the Parameters dialog to Export (Checkmark in the 'Export Parameter' column for that parameter)?
If it was made manually, then you will have to open the Event Triggers dialog on the Manage tab, iLogic panel.  Then make sure the tab named 'This Document' is the active one.  Then drag this iLogic rule from the list on the left, over under the 'iProperty Change' event on the right.  Then click OK.
If it was created automatically from an exported parameter, and this iLogic rule in an 'internal' one (saved within the Inventor document, not external), then we could likely just include the name of the unquoted name of that parameter somewhere within that iLogic rule.  To do that, make a new, empty line at the top/start of that iLogic rule, then create a 'dummy variable' like "oTrigger = MyParamName" (without the quotes).  The name of that parameter will turn blue (by default), signaling that it is recognized as representing a 'local' parameter (within that same document).  Then, whenever the value of that parameter changes, it will cause this rule to run automatically.
Wesley Crihfield
Technology Administrators
