Is there a way to turn off visibility of the UCS with ilogic or the API
The question is in the title - I wasn't able to find an easy way - I'm doing it for screenshots, so I need to toggle it off and on as needed.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Yes, it is possible. Try below iLogic code.
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oUCS As UserCoordinateSystem
For Each oUCS In oDef.UserCoordinateSystems
	If oUCS.Visible = False Then
		oUCS.Visible = True 'Turn on
	Else
		oUCS.Visible = False 'Turn off
	End If
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
The UCS did not change with that code - I'm talking about the UCS in the bottom left corner...
It's turned off in application options by the "Show Origin 3D Indicator" under "Display"
Currently I do it manually before taking a series of screenshots with some iLogic code - but it would be nice to toggle it in the macro.
JamieVJohnson2
Look at Application.DisplayOptions.Show3DIndicator, and ShowXYZAxisLabels, and other options to be found.
jvj
