Is there a way to save a component definition?
JBEDsol
548件の閲覧回数
3件の返信
メッセージ1/4
JBEDsol
I have a code that uses assembly component definitions a lot.  When I try to save as I get errors.  If I'm starting w/ a component def how do I get the documents so that I can save the file?
0 件のいいね
549件の閲覧回数
3件の返信
返信 (3)
メッセージ2/4
JBEDsol
I tried saving the document with this line.
asmDoc.SaveAs(strFileName, False)
I get an error stating
Failed to create folder,""
I've no idea what's going on.
I got the same thing with the line
asmDef.Parent.SaveAs(strFileName, False)
0 件のいいね
メッセージ3/4
snappyjazz
Hello@JBEDsol
If I understand what you're after, the document is part of the component definition. You'll want to convert that to an assembly document. From that assembly document you can save.
Dim SavDoc as Inventor.AssemblyDocument = AsmCompDef.Document
SavDoc.Saveas("FileName",False)
0 件のいいね
メッセージ4/4
dgreatice
where did you get Assembly Component Definition? Drawing?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
0 件のいいね
