Is it valid to look at HealthStatusEnum of a RectangularPatternFeature, and if so what does
kCannotComputeHealth 11783 Object cannot be evaluated.
mean? I have three rectangular patterns which give me three results, the first two good the last one bad:
[16/05/18 08:54:41]:For pattern <R1> eHealth = 11778
[16/05/18 08:54:42]:For pattern <R2> eHealth = 11778
[16/05/18 08:54:57]:For pattern <R> eHealth = 11783
11778 means the object is up to date.
So does "Cannot compute health" and "Object cannot be evaluated" mean that the pattern has gone wrong?
Solved by JaneFan. Go to Solution.
Yes, it is valid to check health status of rectangle pattern feature in this way. For the pattern whose HealthStatus 11783, there should be something wrong. What does it look like in inventor window?
@JaneFanwrote:Yes, it is valid to check health status of rectangle pattern feature in this way. For the pattern whose HealthStatus 11783, there should be something wrong. What does it look like in inventor window?
Thanks for the reply. You're right there was something wrong. Intersecting holes.
So that is solved but the API documentation is not clear. It doesn't say "there's an error" exactly:
Its almost as if it is saying "I don't know about the health or illness of this object, kCannotComputeHealth". I'd prefer it to say "The object is feeling a little off, it can't talk to you to tell you more, but there's probably an error."
