Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Is Edge parallel to Sketchline of extrudefeature
3 REPLIES 3
wj
263 Views, 3 Replies
Hello all,
how do I find out if an edge is parallel to Sketchline of extrudefeature face in C# or VBA?
3 REPLIES 3
JelteDeJong
in reply to: wj
have a look at this iLogic rule:
Dim doc As PartDocument = ThisDoc.Document
Dim extFeature = doc.ComponentDefinition.Features.ExtrudeFeatures.Item(1)
Dim edge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select an edge")
Dim sketch As PlanarSketch = extFeature.Definition.Profile.Parent
Dim plane As Plane = sketch.PlanarEntityGeometry
If (edge.GeometryType <> CurveTypeEnum.kLineCurve And edge.GeometryType <> CurveTypeEnum.kLineSegmentCurve) Then
	MsgBox("This only works with straight edges")
	Return
End If
' Distance check
MsgBox(ThisApplication.MeasureTools.GetMinimumDistance(edge, plane))
' Or
MsgBox(plane.DistanceTo(edge.StartVertex.Point))
MsgBox(plane.DistanceTo(edge.StopVertex.Point))
' Parallel check
Dim curve = edge.Curve(edge.CurveType)
MsgBox(plane.IsParallelTo(curve))
Jelte de Jong
Blog: hjalte.nl - github.com
wj
in reply to: JelteDeJong
Hello JelteDeJong,
thank you for Reply.. I will try it!
wj
in reply to: wj
Hello JelteDeJong,
This code doesn't work right for me, I keep getting wrong values, but helped me get more ideas!  Thank you!
