Iproperty acces with c#
navbor
navbor
Hello All
I am trying to write a small standalone app in C# that I can run when I have an assembly document open.
I want the app to iterate through all the parts in the assembly and set the iproperties. I am having some trouble accessing the iproperties however.
I want (for example) to set the "TITLE" in the "DOCUMENT SUMMARY INFORMATION" to be a concatenation of the part number and the description separated by a " - ".
Can anyone give me some pointers on how to access these properties please.
Thanks in advance
Rob
Regards
Rob
Windows 7 Pro (X64)
Intel(R) core (TM) i5-4690 CPU @ 3.50GHz
32.0 GB RAM
Nvidia Quadro K2000
Autodesk Inventor 2015 Professional Ultimate Design Suite
xiaodong_liang
Autodesk Support
Autodesk Support
The [Title] is stored in [Summary Information], instead of [Summary Information].
 // code snippet
AssemblyDocument odoc = m_inventorApp.ActiveDocument as AssemblyDocument ;
AssemblyComponentDefinition asmDef = odoc.ComponentDefinition;
foreach (ComponentOccurrence oOcc in asmDef.Occurrences)
    Document oDoc = (Document)oOcc.Definition.Document;
    // using GUID to find the "Summary Information"
    PropertySet oPS = oDoc.PropertySets["{F29F85E0-4FF9-1068-AB91-08002B27B3D9}"];
    // using proID to find TITLE
    Inventor.Property oP = oPS.ItemByPropId[(int)PropertiesForSummaryInformationEnum.kTitleSummaryInformation];
    oP.Value = oP.Value + "new";
