Inventor API to Change Component of Ipart
Khoa_NguyenDang
Khoa_NguyenDang
Anyone know how to call this command (Change Component) of iPart in Assembly Environment.
Change ComponentChange ComponentIt will show this table to choose Part of IpartIt will show this table to choose Part of Ipart
Thank guys so much
Accepted solutions (3)
marcin_otręba
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyChangeComponentCmd").Execute
ipart must be selected.
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
marcin_otręba
Sorry not ipart but ipart table must be selected:
Ideas
or check my apps:
JhoelForshav
Hi @Khoa_NguyenDang
You'll need to have the Tables node selected and then execute the command "AssemblyChangeComponentCmd".
The most difficult thing will be finding the correct node since it'll change name if you change iPart-row. If you know it's index or if part of the name is always the same it shouldn't be a problem though.
If you only have one iPart member in the assembly try this 🙂
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane
Dim oOcc As ComponentOccurrence
For Each oOcc In oDoc.ComponentDefinition.Occurrences
	If oOcc.IsiPartMember Then Exit For
Next
Dim oNode As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc) 'Get the iParts node.
oNode.Expanded = True
Dim oTableNode As BrowserNode = oNode.BrowserNodes.Item(1) 'Get the tables node.
oTableNode.DoSelect
Khoa_NguyenDang
@JhoelForshav
Thank you so much. It works perfectly
Khoa_NguyenDang
@marcin_otręba
You're right. I need to choose the Table to us Change Component
Thank you so much for your anwser
Khoa_NguyenDang
@marcin_otręba
Thank for your solution
