parameters update but part doesnt rebuild
william
william
Hello
I have created a rule to automate output of dwg files for varying sizes of the same part. The rule seems to work well, pulling the correct values from the embedded excel spreadsheet but the part doesnt update and rebuild. I have an update command in their, but it doesnt seem to work.
Part file attached. Appreciate any help.
Code is below.
Public Sub Main()
	Dim strPartDoc As Inventor.PartDocument = ThisApplication.ActiveDocument
	Dim strPath = ThisDoc.Path
i = 1 ' the data starts in row 2 not row one, hence the counter start of 1
Do
	i = i + 1
	If String.IsNullOrEmpty (GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1","A" & i)) Then
		MessageBox.Show(i-2 & " Row(s) were read. Row " & i & " was blank", "Rule Completion")
		Return
	Length = GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1","A" & i)
	Width = GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1","B" & i)
	Height = GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1","C" & i)
	iLogicVb.RunRule("Part Number & Description")
	ThisDoc.Document.Rebuild()
	InventorVb.DocumentUpdate()
	strConfigurationName = iProperties.Value("Project", "Description")
	strFileName = strPath & "\" & strConfigurationName & ".dwg"
	Q = MessageBox.Show("Parameters:" + vbCrLf + "Length = " & Length & "" + vbCrLf + "Width = " & Width & "" + vbCrLf + "Height = " & Height & "" + vbCrLf + "Filename: " & strFileName, "Continue", MessageBoxButtons.YesNo, MessageBoxIcon.Warning)
	If Q = vbNo Then
		MessageBox.Show("The rule will cancel", "Error Handling")
		Return
	   ' Get the DWG translator Add-In.
    Dim DWGAddIn As TranslatorAddIn
    DWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
    ' Get the active document.  Can be either a part or assembly.
    Dim doc As Document
    doc = ThisApplication.ActiveDocument
    Dim transObjs As TransientObjects
    transObjs = ThisApplication.TransientObjects
    ' Set up the context to define an output file.
    Dim context As TranslationContext
    context = transObjs.CreateTranslationContext
    context.Type = kFileBrowseIOMechanism
    ' Get the available options from the translator.
    Dim options As NameValueMap
    options = transObjs.CreateNameValueMap
    If DWGAddIn.HasSaveCopyAsOptions(doc, context, options) Then
        ' Set the options for what types of data to write out.
        options.Value("Solid") = True      ' Output solids.
        options.Value("Surface") = False   ' Output surfaces.
        options.Value("Sketch") = False    ' Output sketches.
        ' Set the DWG version.
        ' 23 = ACAD 2000
        ' 25 = ACAD 2004
        ' 27 = ACAD 2007
        ' 29 = ACAD 2010
        options.Value("DwgVersion") = 29
    ' Set the output filename, using a DataMedium object.
    Dim oDataMedium As DataMedium
    oDataMedium = transObjs.CreateDataMedium
    oDataMedium.FileName = strFileName
    ' Call the SaveCopyAs method of the translator add-in.
    Call DWGAddIn.SaveCopyAs(doc, context, options, oDataMedium)
	Loop
End Sub
JhoelForshav
Hi @william
I got it to work by adding RuleParametersOutput()
See code below
Public Sub Main()
Do
	i = i + 1
		Return
	'---------I ADDED THIS--------------
	If Q = vbNo Then
		Return
    Dim doc As Document
        ' 23 = ACAD 2000
        ' 25 = ACAD 2004
        ' 27 = ACAD 2007
        ' 29 = ACAD 2010
	Loop
End Sub
william
Thankyou. Works well now.
