I tried to create an assembly joint. It connects the midpoints of the edges of two faces using a rotational joint. I used python.
My problem is that "Error creating joint definition: (-2147352567, 'Exception occurred.', (0, None, None, None, 0, -2147467259), None)"
Here is my code.
import win32com.client
def AssemblyJoint():
# Initialize Inventor application
invApp = win32com.client.Dispatch("Inventor.Application")
# Create a new assembly document
asmDoc = invApp.Documents.Add(12291, invApp.FileManager.GetTemplateFile(12291, 8962))
asmDef = asmDoc.ComponentDefinition
tg = invApp.TransientGeometry
# Place an occurrence into the assembly
matrix1 = tg.CreateMatrix()
translation_vector1 = tg.CreateVector(0, 0, 0)
matrix1.SetTranslation(translation_vector1)
occ1 = asmDef.Occurrences.Add("C:\\Users\\MINHAZULISLAM\\Desktop\\API Join\\Part1.ipt", matrix1)
matrix2 = tg.CreateMatrix()
translation_vector2 = tg.CreateVector(8 * 2.54, 6 * 2.54, 2 * 2.54) # Converting inches to cm
matrix2.SetTranslation(translation_vector2)
occ2 = asmDef.Occurrences.Add("C:\\Users\\MINHAZULISLAM\\Desktop\\API Join\\Part2.ipt", matrix2)
# Print the structure of the first occurrence
print("Occurrence 1:")
PrintStructure(occ1)
print("\nOccurrence 2:")
PrintStructure(occ2)
# Get faces and edges by index
face1 = occ1.SurfaceBodies.Item(1).Faces.Item(1)
face2 = occ2.SurfaceBodies.Item(1).Faces.Item(1)
edge1 = occ2.SurfaceBodies.Item(1).Edges.Item(1)
edge3 = occ1.SurfaceBodies.Item(1).Edges.Item(1)
# Debugging information
if not face1:
print("Face1 not found")
if not face2:
print("Face2 not found")
if not edge1:
print("Edge1 not found")
if not edge3:
print("Edge3 not found")
# Check if the faces and edges were found
if not face1 or not face2 or not edge1 or not edge3:
raise ValueError("One or more named entities could not be found.")
# Create geometry intents
edge1Intent = asmDef.CreateGeometryIntent(edge1, 1)
edge3Intent = asmDef.CreateGeometryIntent(edge3, 1)
intentOne = asmDef.CreateGeometryIntent(face2, edge1Intent)
intentTwo = asmDef.CreateGeometryIntent(face1, edge3Intent)
# Debugging information for intents
print("Edge1 Intent:", edge1Intent)
print("Edge3 Intent:", edge3Intent)
print("Intent One:", intentOne)
print("Intent Two:", intentTwo)
# Create a rotation joint between the two parts
try:
jointDef = asmDef.Joints.CreateAssemblyJointDefinition(102401, intentOne, intentTwo) # kRotationalJointType
except Exception as e:
print("Error creating joint definition:", e)
return
jointDef.FlipAlignmentDirection = False
jointDef.FlipOriginDirection = True
joint = asmDef.Joints.Add(jointDef)
# Make the joint visible
joint.Visible = True
# Drive the joint to animate it
joint.DriveSettings.StartValue = "0 deg"
joint.DriveSettings.EndValue = "180 deg"
joint.DriveSettings.GoToStart()
joint.DriveSettings.PlayForward()
joint.DriveSettings.PlayReverse()
def PrintStructure(occurrence):
# Print the structure of the occurrence
partDef = occurrence.Definition
surfaceBodies = partDef.SurfaceBodies
print(f"Number of Surface Bodies: {surfaceBodies.Count}")
for i in range(1, surfaceBodies.Count + 1):
surfaceBody = surfaceBodies.Item(i)
print(f" Surface Body {i}:")
print(f" Number of Faces: {surfaceBody.Faces.Count}")
for j in range(1, surfaceBody.Faces.Count + 1):
print(f" Face {j}")
print(f" Number of Edges: {surfaceBody.Edges.Count}")
for k in range(1, surfaceBody.Edges.Count + 1):
print(f" Edge {k}")
# Execute the function
AssemblyJoint()
Solved by YuhanZhang. Go to Solution.
Try below updated code to check if the result is as expected:
if not face1:
if not face2:
if not edge1:
if not edge3:
#edge1Intent = asmDef.CreateGeometryIntent(edge1, 1)
intentOne = asmDef.CreateGeometryIntent(face2, 57867)
intentTwo = asmDef.CreateGeometryIntent(face1, edge3.StopVertex.Point)
# print("Edge1 Intent:", edge1Intent)
try:
return
print(f" Face {j}")
print(f" Edge {k}")
AssemblyJoint()
You used a cylindrical Face to create a GeometryIntent, that you can below Intent values (from PointIntentEnum) to specify which point on the cylindrical axis will be used:
kAxisEndPointIntent 57867
kAxisMidPointIntent 57866
kAxisStartPointIntent 57865
Rocky
