Inventor API Boundary patch for Each Inside Edgeloop
8 REPLIES 8
Message 1 of 9
florian_wenzel
281 Views, 8 Replies
Inventor 2022
API VB.NET Visual Studio
I try to make a BoundaryPatch for Each inside Edgeloop from a Face.
I make only 1 Surrafce. How to do this for each Inside Edgeloop ?
Where is the problem?
This is my Code:
    Public Sub CommandFunctionfweButton_13()
        Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
        Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
        Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
        Dim oFaceTopBody As Face = CType(g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a FaceTopBody"), Face)
        Dim oEdge As Edge
        Dim oEdgeColl As EdgeCollection = oTO.CreateEdgeCollection
        If oFaceTopBody IsNot Nothing Then
            For Each oEdgeloop As EdgeLoop In oFaceTopBody.EdgeLoops
                If Not oEdgeloop.IsOuterEdgeLoop Then
                    For Each oEdge In oEdgeloop.Edges
                        oEdgeColl.Add(oEdge)
                    Next
                    Dim oBoundaryPatchDef As BoundaryPatchDefinition
                    oBoundaryPatchDef = oCompDef.Features.BoundaryPatchFeatures.CreateBoundaryPatchDefinition
                    Call oBoundaryPatchDef.BoundaryPatchLoops.Add(oEdgeColl)
                    For i = 1 To oEdgeColl.Count
                        For Each oEdge In oEdgeColl
                            Call oBoundaryPatchDef.BoundaryPatchLoops.Item(i).SetBoundaryCondition(oEdge, BoundaryPatchConditionEnum.kFreeBoundaryPatchCondition)
                        Next
                        Dim oBoundaryPatch As BoundaryPatchFeature
                        oBoundaryPatch = oCompDef.Features.BoundaryPatchFeatures.Add(oBoundaryPatchDef)
                    Next
                End If
            Next
        End If
    End Sub
Second Code:
    Public Sub CommandFunctionfweButton_14()
        Dim oEdge As Edge
        If oFaceTopBody Is Nothing Then Return
            If oEdgeloop.IsOuterEdgeLoop Then Continue For
            Next
                Call oBoundaryPatchDef.BoundaryPatchLoops.Item(1).SetBoundaryCondition(oEdge, BoundaryPatchConditionEnum.kFreeBoundaryPatchCondition)
            Next
        Next
    End Sub
Only 1 Surface
Thanks for Any Suggestion
8 REPLIES 8
Message 2 of 9
from a quick glance, looks like you are not clearing your edge collection...
try either deleting it after the patch, or limit it's scope to the For-Loop
Message 3 of 9
Hi Lucas.dolinarVFXZU.
Thanks for Solution.
it Works 🙂
Message 4 of 9
can you tell me what you're doing with that patch?
is it for some calculations?
Message 5 of 9
exactly what you said before.
oEdgeColl.Clear
Code:
Imports System.Runtime.InteropServices
Imports Inventor
Imports Microsoft.Win32
Imports System.Collections.Generic
Imports System.Linq
Imports System.IO
Module CommandFunctionButton_14
        Dim oEdge As Edge
            Next
            Next
            oEdgeColl.Clear()
        Next
Message 6 of 9
no, i meant:
why do you need those patches?
does some machine need that? or some other reason?
Message 7 of 9
actualy, to make Holes in other Surface, with ThicknesFeature Symetric,  and then Bool Diference Cut etc...
its a Fragment of a Biger Code
Message 8 of 9
Ah, i see.
professional automation 🙂
thx for answering
Message 9 of 9
i try my best 🙂
step by step, it's gonna be better someday.
Technology Administrators
