Is there a way to specify an icon for light theme and a different one for dark theme just like we can do for big and small icon ? Otherwise, does this mean the only way to adapt my icons is to check ThisApplication.ThemeManager.ActiveTheme.Name every time the events ApplicationEvents.OnApplicationOptionChange is fired ?
Solved by yan.gauthier. Go to Solution.
As far as I know, there is no special property for dar/light themes. But I guess that your alternative is a good solution and not that difficult to implement.
Jelte de Jong
Blog: hjalte.nl - github.com
To those interested. Here is the code I used to make it work (I work with C#, since VB.NET is a dying species)
private string activeTheme;
private void ApplicationEvents_OnApplicationOptionChange(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
if(BeforeOrAfter == EventTimingEnum.kBefore)
activeTheme = InvApp.ThemeManager.ActiveTheme.Name;
else if(BeforeOrAfter == EventTimingEnum.kAfter)
if (activeTheme.Equals("DarkTheme", StringComparison.OrdinalIgnoreCase) && InvApp.ThemeManager.ActiveTheme.Name.Equals("LightTheme", StringComparison.OrdinalIgnoreCase))
SetDarkThemeIcons();
else if (activeTheme.Equals("LightTheme", StringComparison.OrdinalIgnoreCase) && InvApp.ThemeManager.ActiveTheme.Name.Equals("DarkTheme", StringComparison.OrdinalIgnoreCase))
SetLightThemeIcons();
HandlingCode = HandlingCodeEnum.kEventNotHandled; //let Inventor do its thing
