Inventor 2012 sp2 - ilogic and VB Express 2010
Message 1 of 1
Hello!
I know that to use Inventor 2012 sp2 - ilogic and VB Express 2010, you need to publish in .net framework 3.5.
I am doing:
Under Properties (for the solution or project):
Compile -> Advanced Compile Options -> Target Framework
select
.NET Framework 3.5
but I receive an error:
Error in rule: Form Tool, in document: Part1
Could not load file or assembly 'file:///C:\Program Files\Autodesk\Inventor 2012\Bin\iLogicAdd\ClassLibrary1.dll' or one of its dependencies. This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded.
Am I missing something?
Thank you in advance
Fotis
Replies (0)
