Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inspection Dimensions to Table
7 REPLIES 7
Message 1 of 8
max.baumann07
509 Views, 7 Replies
Hello, I need help with a code.
I derive all inspection dimensions into a table.
If the date identifier is K4 as an example, this should also be extracted in column 1. Unfortunately I can't manage this at the moment.
Code:
Dim oDrawingDocument As DrawingDocument
oDrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDocument.ActiveSheet
Dim oCustomTable As CustomTable
Dim oCustomTables As CustomTables
oCustomTables = oSheet.CustomTables
' Delete existing table if it exists
For Each oCustomTable In oCustomTables
    If oCustomTable.Title = "FIELD VERIFICATION DIMENSIONS" Then
        oCustomTable.Delete()
    End If
Next
Dim oInspectionDimension As DrawingDimension
Dim oInspectionDimensionText As DimensionText
Dim oInspectionDimensionString As String
Dim oCellInspectionDimensionItem As Cell
Dim oCellInspectionDimension As Cell
Dim oCellLowestValue As Cell
Dim oCellHighestValue As Cell
Dim oCellMeasurementValue As Cell
Dim oInspectionDimensionCount As Integer
oInspectionDimensionCount = 0
' Count inspection dimensions
For Each oInspectionDimension In oSheet.DrawingDimensions
    If oInspectionDimension.IsInspectionDimension Then
        oInspectionDimensionCount = oInspectionDimensionCount + 1
    End If
Next
' Define table column titles
Dim oColumnTitle(0 To 4) As String ' Adjust size to 5 since we removed the symbol column
oColumnTitle(0) = "Inspection Number"
oColumnTitle(1) = "Inspection Dimension"
oColumnTitle(2) = "Lowest value"
oColumnTitle(3) = "Highest value"
oColumnTitle(4) = "Measurement Value"
' Get the table style and title
Dim oActiveTableStyle As TableStyle
Dim oTableTitle As String
oActiveTableStyle = oDrawingDocument.StylesManager.TableStyles("Inspection_Table")
oTableTitle = oActiveTableStyle.Title
' Create a custom table with specified dimensions and titles
Dim oFieldVerificationTable As CustomTable
oFieldVerificationTable = oSheet.CustomTables.Add(oTableTitle, ThisApplication.TransientGeometry.CreatePoint2d(0.635, oSheet.Height - 0.635), 5, oInspectionDimensionCount, oColumnTitle)
Dim oInspectionDimensionCount2 As Integer
oInspectionDimensionCount2 = 0
' Populate the table with inspection dimension data
        oInspectionDimensionCount2 = oInspectionDimensionCount2 + 1
        oInspectionDimensionText = oInspectionDimension.Text
        oInspectionDimensionString = oInspectionDimensionText.Text
        ' Replace the letter "n" with the diameter symbol (Ø) in the dimension text
        oInspectionDimensionString = Replace(oInspectionDimensionString, "n", ChrW(&H00D8)) ' Ø character
        ' Extract symbols from the dimension string
        Dim symbolPrefix As String
        Dim symbolSuffix As String
        symbolPrefix = ""
        symbolSuffix = ""
        ' Check for symbols at the start and end of the string
        If Len(oInspectionDimensionString) > 0 And Not IsNumeric(Left(oInspectionDimensionString, 1)) Then
            symbolPrefix = Left(oInspectionDimensionString, 1)
        End If
        If Len(oInspectionDimensionString) > 1 And Not IsNumeric(Right(oInspectionDimensionString, 1)) Then
            symbolSuffix = Right(oInspectionDimensionString, 1)
        End If
        ' Assign values to table cells
        oCellInspectionDimensionItem = oFieldVerificationTable.Rows.Item(oInspectionDimensionCount2).Item("Inspection Number")
        oCellInspectionDimensionItem.Value = "K" & oInspectionDimensionCount2 ' Prefix "K" to inspection number
        oCellInspectionDimension = oFieldVerificationTable.Rows.Item(oInspectionDimensionCount2).Item("Inspection Dimension")
        oCellInspectionDimension.Value = oInspectionDimensionString
        ' Check if the dimension is an angle
        Dim isAngle As Boolean
        isAngle = InStr(oInspectionDimensionString, "°") > 0
        If isAngle Then
            ' If it is an angle, calculate values as nominal - 2° and nominal + 2°
            Dim nominalAngle As Double
            nominalAngle = CDbl(Replace(oInspectionDimensionString, "°", "")) ' Remove the ° symbol and convert to double
            Dim lowestAngle As Double
            Dim highestAngle As Double
            lowestAngle = nominalAngle - 2
            highestAngle = nominalAngle + 2
            ' Format the angles to include the ° symbol and two decimal places
            Dim formattedLowestAngle As String
            formattedLowestAngle = Format(lowestAngle, "0.00") & "°"
            Dim formattedHighestAngle As String
            formattedHighestAngle = Format(highestAngle, "0.00") & "°"
            ' Add lowest angle to the table
            oCellLowestValue = oFieldVerificationTable.Rows.Item(oInspectionDimensionCount2).Item("Lowest value")
            oCellLowestValue.Value = formattedLowestAngle
            ' Add highest angle to the table
            oCellHighestValue = oFieldVerificationTable.Rows.Item(oInspectionDimensionCount2).Item("Highest value")
            oCellHighestValue.Value = formattedHighestAngle
        Else
            ' Calculate the lowest and highest values for non-angle dimensions
            Dim nominalValue As Double
            nominalValue = oInspectionDimension.ModelValue
            Dim upperTolerance As Double
            upperTolerance = oInspectionDimension.Tolerance.Upper
            ' Calculate lowest value using symmetrical tolerance
            Dim lowestValue As Double
            lowestValue = (nominalValue - upperTolerance) * 10 ' Assuming a scaling factor of 10
            ' Calculate highest value
            Dim highestValue As Double
            highestValue = (nominalValue + upperTolerance) * 10 ' Assuming a scaling factor of 10
            ' Format lowest and highest values to 2 decimal places
            Dim formattedLowestValue As String
            formattedLowestValue = Format(lowestValue, "0.00")
            Dim formattedHighestValue As String
            formattedHighestValue = Format(highestValue, "0.00")
            ' Add lowest value to the table with symbols
            oCellLowestValue.Value = symbolPrefix & formattedLowestValue & symbolSuffix
            ' Add highest value to the table with symbols
            oCellHighestValue.Value = symbolPrefix & formattedHighestValue & symbolSuffix
        End If
        ' Add measurement value to the table
        oCellMeasurementValue = oFieldVerificationTable.Rows.Item(oInspectionDimensionCount2).Item("Measurement Value")
        oCellMeasurementValue.Value = "" ' Assign your measurement value here
    End If
Next
' Apply the table style to the created table
oFieldVerificationTable.Style = oActiveTableStyle
' Ensure that the document updates after the script execution
iLogicVb.UpdateWhenDone = True
7 REPLIES 7
Message 2 of 8
Stakin
in reply to: max.baumann07
As shown in the figure, the labels in the inspection dimensions and the Datum Identifier and tolerance in the control features frame   can be automatically extracted into the table.Can this meet your requirements?
Dim oSheet As Sheet
    End If
Next
Dim oInsDim As DrawingDimension
Dim oInsDimText As DimensionText
Dim oInsDimString As String
Dim oCellInsDimItem As Cell
Dim oCellMsValue As Cell
oTableTitle ="FIELD VERIFICATION DIMENSIONS"
Dim oFVerTable As CustomTable
Dim oInsDimCt As Integer
oInsDimCt = 0
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oPt2d As Point2d=oTG.CreatePoint2d(0.635, oSheet.Height - 0.635)
For Each oInsDim In oSheet.DrawingDimensions
    If oInsDim.IsInspectionDimension Then
        oInsDimCt = oInsDimCt + 1
		If oInsDimCt =1 Then
			oFVerTable = oSheet.CustomTables.Add(oTableTitle, oPt2d, 5,oInsDimCt, oColumnTitle)
        Else
			oFVerTable.Rows.Add
		End If
		oInsDimText = oInsDim.Text
        oInsDimString = oInsDimText.Text
		Dim oDimShape As InspectionDimensionShapeEnum
		Dim oDimLabel As String
		Dim oDimRate As String
		oInsDim.GetInspectionDimensionData(oDimShape,oDimLabel,oDimRate)
        oInsDimString = Replace(oInsDimString, "n", ChrW(&H00D8)) ' Ø character
        symbolPrefix = ""
        symbolSuffix = ""
        If Len(oInsDimString) > 0 And Not IsNumeric(Left(oInsDimString, 1)) Then
            symbolPrefix = Left(oInsDimString, 1)
        End If
        If Len(oInsDimString) > 1 And Not IsNumeric(Right(oInsDimString, 1)) Then
            symbolSuffix = Right(oInsDimString, 1)
        End If
        oCellInsDimItem = oFVerTable.Rows.Item(oInsDimCt).Item("Inspection Number")
        oCellInsDimItem.Value = oDimLabel
		'"K" & oInsDimCt ' Prefix "K" to inspection number
        oCellInspectionDimension = oFVerTable.Rows.Item(oInsDimCt).Item("Inspection Dimension")
        oCellInspectionDimension.Value = oInsDimString
        isAngle = InStr(oInsDimString, "°") > 0
        If isAngle Then
            nominalAngle = CDbl(Replace(oInsDimString, "°", "")) ' Remove the ° symbol and convert to double
            oCellLowestValue = oFVerTable.Rows.Item(oInsDimCt).Item("Lowest value")
            oCellHighestValue = oFVerTable.Rows.Item(oInsDimCt).Item("Highest value")
        Else
            nominalValue = oInsDim.ModelValue
            upperTolerance = oInsDim.Tolerance.Upper
        End If
        oCellMsValue = oFVerTable.Rows.Item(oInsDimCt).Item("Measurement Value")
        oCellMsValue.Value = "" ' Assign your measurement value here
    End If
Next
For Each oFtConFrame  As FeatureControlFrame In oSheet.FeatureControlFrames
	If oFtConFrame .DatumIdentifier <> "" Then
        Else
			oFVerTable.Rows.Add
		End If
        oCellInsDimItem.Value = oFtConFrame .DatumIdentifier
		oCellInsDimItem = oFVerTable.Rows.Item(oInsDimCt).Item("Inspection Dimension")
        oCellInsDimItem.Value =oFtConFrame .FeatureControlFrameRows.Item(1).Tolerance
	End If
Next
oFVerTable.Style = oActiveTableStyle
Message 3 of 8
Stakin
HI,As shown in the figure, the labels in the inspection dimensions and the Datum Identifier and tolerance in the control features frame   can be automatically extracted into the table.Can this meet your requirements?
Dim oSheet As Sheet
    End If
Next
oInsDimCt = 0
        Else
			oFVerTable.Rows.Add
		End If
        symbolPrefix = ""
        symbolSuffix = ""
        End If
        End If
        If isAngle Then
        Else
        End If
    End If
Next
        Else
			oFVerTable.Rows.Add
		End If
	End If
Next
Message 4 of 8
Hello, thank you very much. That goes in the right direction, I have extended the code again. However, I still have further problems. I replace the symbols such as diameter in the code. In other words, the diameter symbol has the letter n and so that it is displayed correctly in the table, I replace it. However, as soon as I give a dimension a tolerance, the symbols in front of the dimension are no longer displayed. I would also like to see the symbol in front of the shape and position tolerances in the table.
Dim oSheet As Sheet
    End If
Next
oInsDimCt = 0
        Else
			oFVerTable.Rows.Add
		End If
		oInsDimString = Replace(oInsDimString, "j", ChrW(&H2316))
		oInsDimString = Replace(oInsDimString, "e", ChrW(&H25EF))
		oInsDimString = Replace(oInsDimString, "t", ChrW(9008))
		oInsDimString = Replace(oInsDimString, "k", ChrW(8978))
		oInsDimString = Replace(oInsDimString, "d", ChrW(8979))
		oInsDimString = Replace(oInsDimString, "i", ChrW(9007))
		oInsDimString = Replace(oInsDimString, "g", ChrW(9005))
		oInsDimString = Replace(oInsDimString, "r", ChrW(9022))
		oInsDimString = Replace(oInsDimString, "h", ChrW(8599))
		oInsDimString = Replace(oInsDimString, "c", ChrW(&H23E5))
		oInsDimString = Replace(oInsDimString, "b", ChrW(&H221F))
        symbolPrefix = ""
        symbolSuffix = ""
        End If
        End If
        If isAngle Then
        Else
        End If
    End If
Next
        Else
			oFVerTable.Rows.Add
		End If
	End If
Next
Message 5 of 8
unfortunately I have not made any progress with my problem. As soon as a tolerance is defined for a radius or diameter. The diameter symbol is no longer displayed or the R.
Does anyone have any ideas?
Sub Main()
    Dim oSheet As Sheet
        If oCustomTable.Title = "Inspection Dimensions" Then
        End If
    Next
    Dim oCellTolerance As Cell
    Dim oColumnTitle(0 To 6) As String ' Adjust size to 6 since we added the tolerance column
    oColumnTitle(1) = "Symbol"
    oColumnTitle(2) = "Inspection Dimension"
    oColumnTitle(3) = "Tolerance"
    oColumnTitle(5) = "Lowest value"
    oColumnTitle(4) = "Highest value"
    oColumnTitle(6) = "Measurement Value"
    Try
    Catch ex As Exception
        MsgBox("Table style 'Inspection_Table' not found.")
        Exit Sub
    End Try
    oTableTitle = "Inspection Dimensions"
    oInsDimCt = 0
    Dim oPt2d As Point2d = oTG.CreatePoint2d(0.635, oSheet.Height - 0.635)
            If oInsDimCt = 1 Then
                oFVerTable = oSheet.CustomTables.Add(oTableTitle, oPt2d, 7, 1, oColumnTitle) ' Ensure correct number of columns
            Else
                oFVerTable.Rows.Add()
            End If
            oInsDim.GetInspectionDimensionData(oDimShape, oDimLabel, oDimRate)
            ' Replace specific characters with symbols
            symbolPrefix = ""
            symbolSuffix = ""
            End If
            End If
            oCellInsDimItem = oFVerTable.Rows.Item(oInsDimCt).Item("Symbol")
            oCellInsDimItem.Value = symbolPrefix  &" " & symbolSuffix
            ' Add tolerance value to the table
            oCellTolerance = oFVerTable.Rows.Item(oInsDimCt).Item("Tolerance")
            Dim tol As Tolerance
            tol = oInsDim.Tolerance
            If tol.ToleranceType = ToleranceTypeEnum.kSymmetricTolerance Then
                oCellTolerance.Value = "+" & Format(tol.Upper * 10, "0.00") & " / -" & Format(tol.Upper * 10, "0.00")
            Else
                If tol.Upper = tol.Lower Then
                    oCellTolerance.Value = "±" & Format(tol.Lower * 10, "0.00")
                Else
                    If tol.Lower = 0 Then
                        oCellTolerance.Value = "+" & Format(tol.Upper * 10, "0.00") & " / 0.00"
                    Else
                        oCellTolerance.Value = "+" & Format(tol.Upper * 10, "0.00") & " / " & Format(tol.Lower * 10, "0.00")
                    End If
                End If
            End If
            ' Set tolerance cell to empty if no tolerance
            If tol.Upper = 0 And tol.Lower = 0 Then
                oCellTolerance.Value = ""
            End If
            If oCellTolerance.Value = "" Or isAngle Then
                ' If there is no tolerance or it is an angle, leave Lowest value and Highest value empty
                oCellLowestValue.Value = ""
                oCellHighestValue.Value = ""
            Else
                    lowestValue = (nominalValue - tol.Upper) * 10
                Else
                    lowestValue = (nominalValue -- tol.Lower) * 10
                End If
                highestValue = (nominalValue + tol.Upper) * 10
                formattedLowestValue = FormatNumber(lowestValue, 2)
                formattedHighestValue = FormatNumber(highestValue, 2)
                ' Add lowest value to the table without symbols
                oCellLowestValue.Value = formattedLowestValue
                ' Add highest value to the table without symbols
                oCellHighestValue.Value = formattedHighestValue
            End If
        End If
    Next
    ' Process FeatureControlFrames
        If oFtConFrame.DatumIdentifier <> "" Then
                ' Adjust column titles for FeatureControlFrames
                Dim oColumnTitleFC(0 To 1) As String
                oColumnTitleFC(0) = "Inspection Number"
                oColumnTitleFC(1) = "Inspection Dimension"
                oFVerTable = oSheet.CustomTables.Add(oTableTitle, oPt2d, 2, 1, oColumnTitleFC)
            Else
            End If
            oCellInsDimItem.Value = oFtConFrame.DatumIdentifier
            oCellInsDimItem.Value = oFtConFrame.FeatureControlFrameRows.Item(1).Tolerance
        End If
    Next
End Sub
Message 6 of 8
nstevelmans
Hi, seems for me to work just fine, Inventor 2024
Message 7 of 8
Thank you for testing.
The error is indeed no longer present in version 2024. I have tried this with version 2021.
I have now cleaned up my code again.
Now I still have the problem that I can't get the symbols of the shape and position tolerances into the "Symbol" column.
Sub Main()
    Dim oSheet As Sheet
        End If
    Next
    Try
        Exit Sub
    End Try
    oInsDimCt = 0
            Else
            End If
            symbolPrefix = ""
            symbolSuffix = ""
                oInsDimString = Mid(oInsDimString, 2) ' Remove prefix
            End If
                oInsDimString = Left(oInsDimString, Len(oInsDimString) - 1) ' Remove suffix
            End If
            oCellInsDimItem.Value = symbolPrefix & " " & symbolSuffix
            Else
                Else
                    Else
                    End If
                End If
            End If
            End If
            Else
                Else
                    lowestValue = (nominalValue - tol.Lower) * 10
                End If
            End If
        End If
    Next
            Else
            End If
        End If
    Next
End Sub
Function GetDimensionIdentifier(ByVal oInsDim As DrawingDimension) As String
    Dim oDimIdentifier As String = "K" ' Initialize with "K" prefix
    If TypeOf oInsDim Is LinearGeneralDimension Then
        oDimIdentifier = oDimIdentifier & Format(oInsDim.ModelValue, "0.00")
    ElseIf TypeOf oInsDim Is DiameterGeneralDimension Then
    ElseIf TypeOf oInsDim Is RadiusGeneralDimension Then
    ElseIf TypeOf oInsDim Is AngularGeneralDimension Then
    End If
    Return oDimIdentifier
End Function
Message 8 of 8
nstevelmans
Hi, you can grab the symbol from an featurecontrol frame whit this
Dim oGeoChar As String = oRow.GeometricCharacteristic.ToString
 You have to expand the list
  Dim oDimTextValue = oGeoChar
                ' Replace the symbols
                oDimTextValue = Replace(oDimTextValue, "kCircularity", ChrW(&H25EF))
                oDimTextValue = Replace(oDimTextValue, "kTotalRunout", ChrW(9008))
                oDimTextValue = Replace(oDimTextValue, "kPosition", ChrW(&H2316))
I have reworked the code to check if this is right.
Sub Main()
    Dim oSheet As Sheet
        End If
    Next
    Try
        Exit Sub
    End Try
    oInsDimCt = 0
            Else
            End If
            symbolPrefix = ""
            symbolSuffix = ""
            End If
            End If
            Else
                Else
                    Else
                    End If
                End If
            End If
            End If
            Else
                Else
                End If
            End If
        End If
    Next
                Dim oColumnTitleFC(0 To 2) As String
                oColumnTitleFC(1) = "Symbol"
				oColumnTitleFC(2) = "Inspection Dimension"
            Else
            End If
					' Create a FeatureControlFrameRows object to define the symbol's rows
                Dim oRows As FeatureControlFrameRows = oFtConFrame.FeatureControlFrameRows
                Dim oRow As FeatureControlFrameRow = oRows.Item(1)
            oCellInsDimItem.Value = oDimTextValue
        End If
    Next
End Sub
    End If
End Function
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
