Imports System
Imports System.Collections.Generic
Imports System.Linq
Imports System.Text
Imports Inventor
Imports System.Runtime.InteropServices
Dim m_inventorApp As Inventor.Application = Nothing
m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
Dim oAssyDoc As AssemblyDocument
oAssyDoc = m_inventorApp.ActiveDocument
Dim oAssyDef As AssemblyComponentDefinition
oAssyDef = oAssyDoc.ComponentDefinition
' Select a circular edge on the component to be inserted
Dim partEdge As Edge
partEdge = m_inventorApp.CommandManager.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select a circular edge.")
If partEdge Is Nothing Then
Exit Sub
End If
' Get the occurrence of the component that contains the selected edge
Dim Occurrence As ComponentOccurrence
Occurrence = partEdge.Parent.Parent
' Select all the occurrences related to the component that contains the selected edge
Dim tr As TransientObjects
tr = m_inventorApp.TransientObjects
Dim coll As ObjectCollection
coll = tr.CreateObjectCollection()
Dim ac As AssemblyConstraint
For Each ac In Occurrence.Constraints
coll.Add(ac.OccurrenceOne)
coll.Add(ac.OccurrenceTwo)
Next
Dim occ As ComponentOccurrence
For Each occ In coll
oAssyDoc.SelectSet.Select(occ)
Next
' Select a hole on the steel plate to insert the component into
Dim oObject As Object
oObject = m_inventorApp.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select a hole on the steel plate to insert the component into")
If oObject Is Nothing Then
Exit Sub
End If
' Insert the component into the hole on the steel plate
Dim oInsert As InsertConstraint
oInsert = oAssyDef.Constraints.AddInsertConstraint(oObject, partEdge, True, 0)
' Select all the occurrences related to the inserted component
Dim newOccurrence As ComponentOccurrence
newOccurrence = oInsert.OccurrenceTwo
coll.Clear()
For Each ac In newOccurrence.Constraints
Next
Next
' Select all the occurrences related to the copied and pasted component
Dim pasteOccurrence As ComponentOccurrence
pasteOccurrence = oAssyDef.Occurrences.Item(oAssyDef.Occurrences.Count)
coll.Clear()
For Each ac In pasteOccurrence.Constraints
Next
Next
InventorVb.DocumentUpdate()
Solved by yuzeaa. Go to Solution.
Solved by Andrii_Humeniuk. Go to Solution.
Hi @haphanthanhtam.work . If you wanted your rule to automatically place a bolt in all holes, then try this rule:
Sub main()
Dim oDoc As Document = ThisDoc.Document
If Not TypeOf oDoc Is AssemblyDocument Then Exit Sub
Dim oAsmDoc As AssemblyDocument = oDoc
Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim partEdge, oObj, oNewEdge As Edge
Dim oCM As CommandManager = ThisApplication.CommandManager
partEdge = oCM.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select a circular edge.")
If partEdge Is Nothing Then Exit Sub
If partEdge.Parent.Parent.Constraints.Count > 0 Then Exit Sub
Dim bQuest As Boolean = True
Do
oObj = oCM.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select a hole on the steel plate to insert the component into")
If oObj Is Nothing Then Exit Sub
Dim oObjCircle As Circle = oObj.Geometry
If bQuest Then
oInsert = oAsmDef.Constraints.AddInsertConstraint(oObj, partEdge, True, 0)
Else
oNewEdge = GetNewOccEdge(oAsmDef, partEdge)
oInsert = oAsmDef.Constraints.AddInsertConstraint(oObj, oNewEdge, True, 0)
End If
If bQuest Then
Dim oColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
For i As Integer = 1 To oObj.Faces.Count
If oObj.Faces(i).SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
For iEdge As Integer = 1 To oObj.Faces(i).Edges.Count
If oObj.Faces(i).Edges(iEdge).GeometryType = CurveTypeEnum.kCircleCurve Then
If oObj.Faces(i).Edges(iEdge).Geometry.Radius = oObjCircle.Radius Then oColl.Add(oObj.Faces(i).Edges(iEdge))
End If
Next iEdge
Exit For
End If
Next i
boxYes = MessageBox.Show("You want To place the bolt In all the holes (" & oColl.Count & ")?", _
"Insert Multple Bolt", MessageBoxButtons.YesNo, MessageBoxIcon.Question, _
MessageBoxDefaultButton.Button1)
If boxYes = vbYes Then
For i As Integer = 1 To oColl.Count
If oColl(i) Is oObj Then Continue For
oInsert = oAsmDef.Constraints.AddInsertConstraint(oColl(i), oNewEdge, True, 0)
Next i
Exit Do
Else
bQuest = False
End If
End If
Loop
oAsmDoc.Update()
End Sub
Private Function GetNewOccEdge(oAsmDef As AssemblyComponentDefinition, partEdge As Edge) As Edge
Dim oPartDoc As PartDocument = partEdge.Parent.Parent.Definition.Document
Dim oMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
oNewOcc = oAsmDef.Occurrences.Add(oPartDoc.FullDocumentName, oMatrix)
For iBody As Integer = 1 To oNewOcc.SurfaceBodies.Count
If oNewOcc.SurfaceBodies(iBody).Name = partEdge.Parent.Name Then
For iEdge As Integer = 1 To oNewOcc.SurfaceBodies(iBody).Edges.Count
If oNewOcc.SurfaceBodies(iBody).Edges(iEdge).TransientKey = partEdge.TransientKey Then
Return oNewOcc.SurfaceBodies(iBody).Edges(iEdge)
End If
Next iEdge
End If
Next iBody
Return Nothing
End Function
I completely rewrote your rule.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
It works with a single Part, but it does not work with multiple constrained Parts or an Sub-Assembly.
How does it work with all problems
Hi @Andrii_Humeniuk
from your generated code is it possible to convert it a bit
Hi @haphanthanhtam.work . AxesOpposed = False
No problem. I changed lines 18, 21 and 42.
Sub main()
' If partEdge.Parent.Parent.Constraints.Count > 0 Then Exit Sub
Do
If bQuest Then
oInsert = oAsmDef.Constraints.AddInsertConstraint(oObj, partEdge, False, 0)
Else
oInsert = oAsmDef.Constraints.AddInsertConstraint(oObj, oNewEdge, False, 0)
End If
If bQuest Then
End If
Next iEdge
Exit For
End If
Next i
oInsert = oAsmDef.Constraints.AddInsertConstraint(oColl(i), oNewEdge, False, 0)
Next i
Exit Do
Else
bQuest = False
End If
End If
Loop
oAsmDoc.Update()
End Sub
End If
Next iEdge
End If
Next iBody
Return Nothing
End Function
I made some modifications to @Andrii_Humeniuk's code to make it work for multiple constrained Parts.
Sub main()
GetMultiOcc(partEdge.Parent.Parent)
MultiOccs = ThisApplication.TransientObjects.CreateObjectCollection
occlist.ForEach(Function(entity) MultiOccs.Add(entity))
oDoc.SelectSet.SelectMultiple(MultiOccs)
ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd").Execute() 'ctrl+c MultiOccs
oDoc.SelectSet.clear
Do
If bQuest Then
Else
ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd").Execute()
oNewEdge = GetNewOccEdge(GetNewOcc(oAsmDef,partEdge), partEdge)
End If
If bQuest Then
End If
Next iEdge
Exit For
End If
Next i
Next i
Exit Do
Else
bQuest = False
End If
End If
Loop
oAsmDoc.Update()
End Sub
Private Function GetNewOcc(oAsmDef As AssemblyComponentDefinition,partEdge As Edge) As ComponentOccurrence
For i = oAsmDef.Occurrences.Count To oAsmDef.Occurrences.Count - occlist.count Step -1
If oAsmDef.Occurrences(i).Definition.Document.FullDocumentName = oPartDoc.FullDocumentName Then
Return oAsmDef.Occurrences(i)
Exit Function
End If
Next
End Function
Private Function GetNewOccEdge(oNewOcc As ComponentOccurrence, partEdge As Edge) As Edge
End If
Next iEdge
End If
Next iBody
Return Nothing
End Function
Dim occlist As New List(Of ComponentOccurrence)
Private Sub GetMultiOcc(occ As ComponentOccurrence)
occlist.Add(occ)
Dim InsertConstraints As New List(Of InsertConstraint)
InsertConstraints = occ.Constraints.OfType(Of InsertConstraint).ToList()
If InsertConstraints.Count = 0 Then
Exit Sub
Else
For Each InsertConstraint As InsertConstraint In InsertConstraints
Dim occ1 = InsertConstraint.OccurrenceOne
If occ1.name <> occ.Name AndAlso Not occlist.contains(occ1)Then GetMultiOcc(occ1)
Dim occ2 = InsertConstraint.OccurrenceTwo
If occ2.name <> occ.Name AndAlso Not occlist.contains(occ2)Then GetMultiOcc(occ2)
Next
End If
End Sub
