Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
iLogicVB.UpdateWhenDone - Preventing Check-In
6 REPLIES 6
scott.314
784 Views, 6 Replies
Since updating to Inventor 2017 from Inventor 2015 we have run into multiple issues, but here is the latest.
I have been checking our stock assemblies out of Vault (to fix the appearance and migrating issues that popped up in 2017), and now I can not check the assemblies back in as long as our iLogic rules contain the iLogicVB.UpdateWhenDone = True code.
I don't get any errors, it simply will not check in. I will attach two screenshots of what the check-in window looks like. If I comment out the Update code, it will check in both the assembly and the part. If I do not comment out the Update code, it will only check in the part.
Anyone know what this is about? I would sure like to keep the Update code in our iLogic (as most of our assemblies contain this code).
6 REPLIES 6
Mark.Lancaster
in reply to: scott.314
Do you have this code running based on a triggered event?  If so make sure the trigger is not happening "AFTER SAVE".
Mark Lancaster
scott.314
in reply to: Mark.Lancaster
SyntaxEditor Code Snippet
MultiValue.List("CatchBasinDia") = GoExcel.CellValues("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "Catch Basin", "B7", "B18")
GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "F5") = CatchBasinDia
GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "D5") = "MonoBase"
GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "F10") = "BaseHeight"
GoExcel.DisplayAlerts = False
Parameter("CB MonoBase-01:1", "Height") = BaseHeight
Parameter("CB MonoBase-01:1", "OD") = GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "E13")
Parameter("CB MonoBase-01:1", "ID") = GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "F13")
Parameter("CB MonoBase-01:1", "JT") = GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "D16")
Parameter("CB MonoBase-01:1", "RD") = GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "E16")
Parameter("CB MonoBase-01:1", "FThk") = GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "F19")
Parameter("CB MonoBase-01:1", "LiftPinRad") = GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "E23")
Parameter("CB MonoBase-01:1", "LiftPinDrop") = GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "F23")
Parameter("CB MonoBase-01:1", "Sump") = Sump
Parameter("CB MonoBase-01:1", "SumpPipeDia") = HoleDia
iLogicVb.UpdateWhenDone = True
If CatchBasinDia = 600 Then
MultiValue.List("BaseHeight") = GoExcel.CellValues("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "Catch Basin", "N7", "N12")
Sump = 500
HoleDia = 356
TwoHoles = False
Keyway = False
WeeperHoles = False
Parameter("CB MonoBase-01:1", "Height") = BaseHeight-GoExcel.CellValue("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "CB Dimensions", "F19")
Feature.IsActive("CB MonoBase-01:1", "600 Leak Ring") = True
MessageBox.Show("Dimensions may not be correct due to lack of information at this time. Please review ALL dimensions.", "WARNING")
Else If CatchBasinDia = 900 Then
MultiValue.List("BaseHeight") = GoExcel.CellValues("C:\_Workspace\Designs\05 - Reference\Master Catch Basin Information.xlsx", "Catch Basin", "N13", "N18")
Feature.IsActive("CB MonoBase-01:1", "600 Leak Ring") = False
If Keyway = True Then
Feature.IsActive("CB MonoBase-01:1", "TopKeyway") = True
Feature.IsActive("CB MonoBase-01:1", "Chamfer1") = True
Else If Keyway = False Then
Feature.IsActive("CB MonoBase-01:1", "TopKeyway") = False
Feature.IsActive("CB MonoBase-01:1", "Chamfer1") = False
If WeeperHoles = True Then
Feature.IsActive("CB MonoBase-01:1", "Weeper1") = True
Feature.IsActive("CB MonoBase-01:1", "Weeper2") = True
Else If WeeperHoles = False Then
Feature.IsActive("CB MonoBase-01:1", "Weeper1") = False
Feature.IsActive("CB MonoBase-01:1", "Weeper2") = False
If TwoHoles = True Then
Feature.IsActive("CB MonoBase-01:1", "TwoHole") = True
Parameter("CB MonoBase-01:1", "Pipe2Angle") = Hole2Angle
Parameter("CB MonoBase-01:1", "Pipe2Dia") = Hole2Dia
Else If TwoHoles = False Then
Feature.IsActive("CB MonoBase-01:1", "TwoHole") = False
No, it is not based on a triggered event. This is the entire code.
With this particular assembly (I just checked a random one out from vault), I cannot check in even with both of those Update snippets commented out. So something else must be stopping it.
[edit] And again, this was NOT an issue in Inventor 2015. It worked fine until we installed Inventor 2017.
scott.314
It appears to be an issue specific to these catch basin assemblies. We have two options 600, and 900 but do not have complete information in the referenced spreadsheet for 600. It didn't like something to do with that. In order to get it checked in I had to delete all code relating to the 600 option. As well, I still had to comment out the UpdateWhenDone code.
I have moved on to different structures entirely and haven't run into issues with the UpdateWhenDone code (they checked in just fine).
scott.314
False alarm. There is definitely some new issue that Inventor 2017 has with our iLogic. I have run into this again with various other previously working assemblies. I have to go through all the rules and comment out iLogicVB.UpdateWhenDone = True
I have no idea why. I can't see any issues with the code.
scott.314
OK, so for anyone that cares I will give a complete rundown of what works and what doesn't for this issue. I have a feeling it may be something Vault related.
So we update (for lack of a better word, as it certainly hasn't been an upgrade) to Inventor 2017. I have been working the same way I always have. I checked out an assembly from vault. I want to change everything in the assembly so I right click on top level assembly, go down to Vault, click Check Out, proceed to check out all children parts/assemblies. Make changes, go to check back into vault the same way (right click on top level assembly, go down to Vault, click Check In). The Check In window pops up and shows everything except the parent assembly. As mentioned previously, I found that I can go into my iLogic rules, comment out the UpdateWhenDone snippet, then when I go to Check In, the window shows that it is checking in everything including the parent assembly. Weird.
So after playing with this all morning, double checking event triggers to make sure it wasn't running any rules that would conflict with the Check In procedure. All looked well. For some reason I tried clicking over to the Vault tab and clicking that Check In button. It works. With the UpdateWhenDone snippet running as normal, it will check everything in as normal. So I click cancel, try checking in the other way (right click, Vault, Check In) and it works now.
Some sort of bug in 2017?
ADSKDJW4
Hello @scott.314,
I will ask for this post to be moved into the Inventor customization forum where its better suited.
Best Regards,
Don
