I'm having a strange problem with iLogic trigger events.
A trigger event suddendly appeared to all my files : new files, recent files, and old files. IPT, IAM, DWG files also.
So it seems to appear suddendly to thousand files.
And I can't suppres it :
This rule is one of my external rules, to launch from a drawing, so when I open an assembly I have an error message for each file...😱
But how this could happen ?
And how fix it ? 😥
Here attached some example files to be sure.
PS : A few days before the end of the contest, hooo !
Thomas
Mechanical Designer / Inventor Professionnal 2025
Solved by mcgyvr. Go to Solution.
Look on the "All Documents" (Tous Les Documents) tab.
Any rules set there?
Maybe you accidentally added it there vs "this document" tab..
