Ilogic to search the file, open it and do something
Im looking for a code in vb.net that could search the file (in my case for now .ipt), open it and do something like convert, add parameters etc. Usually the file names comes as  list in excel.
This code can search but doesnt do much.
If System.IO.Directory.GetFiles("C:\Inventor Study\", "Test.ipt", IO.SearchOption.AllDirectories).Length > 0 Then
    MsgBox("Found!")
Else
    MsgBox("Not found!")
End If
 This one got error: textbox_sa is not decleared.
Dim allFiles As IEnumerable(Of String) = System.IO.Directory.EnumerateFiles("C:\Inventor Study\", "Test.ipt", IO.SearchOption.AllDirectories)
Dim filePaths As IList(Of String) = allFiles.Where(Function(f) f.IndexOf(TextBox_sa.Text, StringComparison.OrdinalIgnoreCase) <> -1).ToList()
If filePaths.Count = 0 Then
    MessageBox.Show("File not found")
Else
    For Each filePath As String In filePaths
        System.Diagnostics.Process.Start(filePath)
    Next
End If
 Thank you.
FINET_Laurent
Where do you want to open the document from ?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Hi @FINET_Laurent . I'd like to open it in Inventor.
FINET_Laurent
From the start menu ? From an assembly file ?
FINET L.
The code will search the file using ilogic. If found, it should open it in Inventor.
JhoelForshav
Hi @Anonymous
Try this 🙂
Dim oFolder As String = "C:\Inventor Study"
Dim oName As String = "Test.ipt"
If System.IO.Directory.Exists(oFolder) = False
	MessageBox.Show("The directory: " & oFolder & " doesn't exist!", "Invalid directory", _
	MessageBoxButtons.OK, MessageBoxIcon.Error)
Exit Sub
End If
Dim oFoundDocs As String() = System.IO.Directory.GetFiles(oFolder, oName, IO.SearchOption.AllDirectories)
If oFoundDocs.Length > 0 Then
    For Each oPath As String In oFoundDocs
		ThisApplication.Documents.Open(oPath, True)
	Next
Else
    MessageBox.Show("Couldn't find the document " & oName & " in " & oFolder & " or any of its sub folders!", _
	"No file found", _
	MessageBoxButtons.OK, MessageBoxIcon.Information)
End If
GetFiles returns an array of strings with the filepaths to all the found documents.
It works like magic. A super mega THANK YOU @JhoelForshav .
