ilogic to read different sheets/tabs in excel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was wondering if anyone knows a code or a way to get inventor to recognize which sheets/tabs to read points from excel without any parameters in that sketch. I've been helped with this code
GoExcel.CellValue("filename.xls", "Sheet1", "A2")
but its not what I am trying to do.. I need it to let the user pick which excel file to use and which sheet/tabs to read the x-y coordinates from. The command I have is this
Sub Main()
' Get the CommandManager object.
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
' Get control definition for the line command.
Dim oControlDef As ControlDefinition
oControlDef = oCommandMgr.ControlDefinitions.Item( _
"SCxImportPointsCmd")
' Execute the command.
Call oControlDef.Execute
End Sub
now the question is how do i get it to read like sheet 2 instead of sheet 1? keep in mind the sketch is just importing in points.. it has no parameters or anything to let inventor know to replace a number or where the points are at. I can't use parameters because the points are going to be clear each time a new x-y coordinates are being generated.
