iLogic to Export Step from **** marked as Normal in BOM
4 REPLIES 4
frederik_vollbrecht
3703 Views, 4 Replies
i have found the following line of code here. I want to export only Parts from the **** witch are marked as "Normal" in the BOM Structure.
 Anyone has a solution?
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
    MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
    Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a STEP file for all components." _
& vbLf & " " _
& vbLf & "Are you sure you want to create STEP Drawings for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output STEPs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
    Return
Else
End If
'- - - - - - - - - - - - -STEP setup - - - - - - - - - - - -
oPath = ThisDoc.Path
'get STEP target folder path
oFolder = oPath & "\" & oAsmName & " STEP Files"
'Check for the step folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Assembly - - - - - - - - - - - -
ThisDoc.Document.SaveAs(oFolder & "\" & oAsmName &(".stp") , True)
'- - - - - - - - - - - - -Components - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the referenced models
For Each oRefDoc In oRefDocs
	ThisDoc.Document.ComponentDefinition.BOMStructure  =  BOMStructureEnum.kNormalBOMStructure
    Dim oCurFile As Document
    oCurFile = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
    oCurFileName = oCurFile.FullFileName
    'defines backslash As the subdirectory separator
    Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
    'find the postion of the last backslash in the path
    FNamePos = InStrRev(oCurFileName, "\", -1)
    'get the file name with the file extension
    Name = Right(oCurFileName, Len(oCurFileName) - FNamePos)
    'get the file name (without extension)
    ShortName = Left(Name, Len(Name) - 4)
If ThisDoc.Document.ComponentDefinition.BOMStructure  <>  BOMStructureEnum.kPurchasedBOMStructure Then
    Try
        oCurFile.SaveAs(oFolder & "\" & ShortName & (".stp") , True)
    Catch
        MessageBox.Show("Error processing " & oCurFileName, "ilogic")
    End Try
    oCurFile.Close
	Else
	oCurFile.Close
	End If
Next
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new files are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
4 REPLIES 4
I shortend Assembly with A.-A.-S witch was filtered 🙂
Solved by myself:
    Exit Sub
End If
'get user input
& vbLf & " " _
    Return
Else
End If
End If
'- - - - - - - - - - - - -Assembly Export- - - - - - - - - - - -
'ThisDoc.Document.SaveAs(oFolder & "\" & oAsmName &(".stp") , True)
	If oRefDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
    	Try
    	Catch
    	End Try
	End If
	oCurFile.Close
	Next
in reply to: frederik_vollbrecht
I suppose this is simple, but how can I save the .step files as the .ipt part number instead of the file name?
If I can get that changed would be great.
Hey, it works great!
I got a question,
I want to save my .step files as part number as name,
how i have to change the code to do this ?
thanks for any reply 😉
Technology Administrators
