Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
iLogic to determin whether a dimension on drawing is angular?
5 REPLIES 5
engilic
711 Views, 5 Replies
Is it possible by iLogic to determin whether a dimension is angular or not?
I know it is possible to add angular dimension by AddAngular but is it possible to check the existing one?
I could not find any difference between Linear and Angular dimension except that the Precision parameter in the Edit Dimension window is called Primary Unit or Angular Unit and also Tolerance Precision called Primary Tolerance and Angular Tolerance but actually, they belong to the same parameters Precision and TolerancePrecision so I cannot use Try-Catch to determine whether the dimension is Angular or Linear, maybe there is some other way, something else that make difference between Linear and Sngular dimensions.
Thank you
Have a lovely day.
Labels (3)
5 REPLIES 5
Ralf_Krieg
in reply to: engilic
Hello
Check the Dimension.Type if it is ObjectTypeEnum.kLinearGeneralDimensionObject or ObjectTypeEnum.kAngularGeneralDimensionObject
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
engilic
Thank you @Ralf_Krieg ,
so simple.
Thank you very much
m.joudivand
in reply to: Ralf_Krieg
Could you also write the Enum Object Type for the diametric/radial dimensions for iLogic, please?
Ralf_Krieg
Hello
kDiameterGeneralDimensionObject and kRadiusGeneralDimensionObject
R. Krieg
RKW Solutions GmbH
m.joudivand
Thank you very much @Ralf_Krieg
