iLogic To Create Sweep
4 REPLIES 4
felix.cortes5K3Y2
960 Views, 4 Replies
Hi Forum,
I want to create a sweep from two sketches but I do not know how to work it out.
So far, here's what I got
	Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oSketch1 As Sketch = "Sketch1"
	Dim oSketch2 As Sketch = "Sketch2"
	Dim oCompDef As PartComponentDefinition
	oCompDef = oPartDoc.ComponentDefinition
	oSweep = oCompDef.Features.SweepFeatures.Add.....???
I'd like to create the sweep from oSketch1 and oSketch2 but do not know how to follow up the syntax to do so.
Best regards,
Felix Cortes
4 REPLIES 4
SweepDefinition is the missing link here.
Define a SweepDefinition object and use SweepFeatures.CreateSweepDefinition
Use that to create the sweep with the Add command.
jvj
Hi, To create a swepp with a single line route, for example, you could use something like this. Sketch1 is the sketch of the profile, and sketch2 is the sketch of the route.
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
' Create a profile.
Dim oSketch1 As Sketch = oCompDef.Sketches.Item("Sketch1")
Dim oProfile As Profile = oSketch1.Profiles.AddForSolid
' Create a path.
Dim oSketch2 As Sketch = oCompDef.Sketches.Item("Sketch2")
Dim oPath As Path = oCompDef.Features.CreatePath(oSketch2.SketchLines(1))
' Create the sweep feature.
Dim oSweep As SweepFeature = oCompDef.Features.SweepFeatures.AddUsingPath(oProfile, oPath, kJoinOperation)
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks Sergio, this worked
Hey Sergio,
I am trying to add a Rectangular pattern onto the newly created sweep but it doesn't seem to work. Here's what I've tried so far:
' Create a profile.
' Create a path.
oSweep.Name = "Test"
'Dim TestPattern As RectangularPatternFeature = oCompDef.Features.RectangularPatternFeatures.Add("TestPattern", 3, 20 in, Nothing, "X Axis")
'Dim TestPatter0 As RecantgularPatternFeature = oCompDef.Features.RectangularPatternFeatures
'TestPatter0.CreateDefinition("Test", "X Axis", True, 3, "20 in")
Dim TestPattern As RecantgularPatternFeature = oCompDef.Features.RectangularPatternFeatures.CreateDefinition("Test", "X Axis", True, 3, "20 in")
The code fails on the last line.
Technology Administrators
