Ilogic ... switch Sketch symbol "A" TO "B"
mdavis22569
Mentor Mentor
Message 1 of 10
mdavis22569
I've been looking for a bit and have zero luck ...
I'm looking for a way to change a note that was set up as a Sketch symbol ..I want to change the note "Sand Lightly" to say "Anodize"
Mike
Mike Davis
Replies (9)
Message 2 of 10
mdavis22569
I have the insert a certain sketch symbol Weld or schweißen     ...just need it to delete option "weld" if it's in the IDW already and insert Sketch Symbol "schweißen" or vice versa
Thoughts
Mike Davis
Message 3 of 10
MechMachineMan
Yes this is possible.
There is no "swap", but you can grab the symbol, pull the position/rotation/leader info from in and use that in inserting your new symbol.
You can also just go through the current symbols, get the string of text that resides within the textbox and use the [STRING].Replace(ReplaceThis, WithThis) functionality available in vb
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 10
mdavis22569
What I'm trying to do is ...
I'd like to say if value "a" is true then replace it with symbol "b"
The issue is ..I need to have a flip option for German and English.   We have a few designers and shops we use in the US...and 200 plus in Germany. So right now anything we do in the US, we have to translate manually. However we're expanding in the US so we're sourcing more work here.   I have the title block swapping/toggling with Ilogic, just not the finish notes.     The reason we don't just replace them completely to English is if we design something here in the US, I may have to build it in Germany, so I need the notes in German..     which means more manual translating or changing.
Mike Davis
Message 5 of 10
MechMachineMan
Yes?
For Each sheet in doc
For each sketchsymbol
If SketchSymbol.Name = a
oNewPos = SketchSymbol.Position
SketchSymbols.Add(SketchSymbol B, oNewPos)
.... and so on
If you have leaders attached that becomes a fair bit lengthier.
Justin K
Message 6 of 10
mdavis22569
nope no leaders ...
it goes right above the title block
Mike Davis
Message 7 of 10
mdavis22569
Thank you too Justin,
Ilogic and I aren't the best of friends ..lol.    I just haven't had the time to play with it ...
I tried yours ..and got a lot of errors ... suggestions.
AGAIN THANK YOU!
Mike Davis
Message 8 of 10
MechMachineMan
Yeah, what I posed was just pseudo code to show how it would be done.
Justin K
Message 9 of 10
mdavis22569
Dang ...got all excited ...
Mike Davis
Message 10 of 10
MechMachineMan
Check the other thread. I posted a version that should work there seeing as Xiadong had it mostly typed up for me 🙂
Justin K
