ILOGIC SNIPPET ERROR
Hi Everyone,
I have a run into an error. I know what the cause is but am having some difficulty figuring out a solution.
I have a wall that can be either be a wall or a cargo door.
The wall has several features that can be controlled. Cutouts etc..
The problem is when I select cargo door all the wall parts are suppressed but the code runs regardless for the wall features and gives me the following(see attached).
The problem goes away when I remove all the code related to wall features.
I hope this makes sense. Is there a way I can solve this??
Michael
FINET_Laurent
You should use the try/catch function.
Try
	'try the command that gives error
Catch
	'do nothing
End Try
Here is a bit of documentation.
https://knowledge.autodesk.com/support/inventor-engineer-to-order/learn-explore/caas/CloudHelp/cloud...
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Cheers for the reply
so the same code? now I have
If
else if
end if
Do I just replace with your solution?
FINET_Laurent
You can keep the same code and add the try/Catch.
If "what ever it is" Then
	Try
		'Try the block of commands that is giving error on certain circumstances (if it can then it does,if not it skips the line so you don't get the error message and the rule doesn't stop
	Catch
		'what you want to happen if it gives an error (Nothing in this case from what i understand
	End Try
Else If
 Hope this is clear. If not can you share the code ?
FINET L.
I tried it and it seems to have worked.
