I am trying to access a Yes/No property in ("Inventor User Defined Properties") and upon the value of property I need to add further code. I am struggling to get through to it. Any help guiding me will be really appreciated.
Sub AddStandParts()
Dim oAssyDoc As AssemblyDocument
Dim oPartdoc As PartDocument
Set oAssyDoc = ThisApplication.ActiveDocument
Dim oOccu As ComponentOccurrence
Dim oOccuS As ComponentOccurrences
Set oOccuS = oAssyDoc.ComponentDefinition.Occurrences
For Each oOccu In oOccuS
Dim invCustomPropertySet As PropertySet
If oOccu.Definition.Document.ProperSet Then 'Ceartain property set is found, need help here
MsgBox ("Standard Item")
Else
MsgBox ("Custom Item")
Next
End Sub
best regards,
sam
