Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic - Run Rule only one time.
7 REPLIES 7
Message 1 of 8
ratneshmalik1990
1553 Views, 7 Replies
I have made tube with varying length.
I placed part in assembly by using "Place iLogic component". and save the assembly.
but after re opening the assembly - again getting dialogue box for enter the length.
i already enter the length in 1st time when created assembly
Autodesk Inventor Certified Professional | Mechanical Design Engineer
7 REPLIES 7
Message 2 of 8
What event trigger is causing your iLogic rule to run?
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 3 of 8
I want iLogic rule runs only once and after the variable change it stops on that situation.
And when I place part in assebly it doesn't pop up again for variable.
E.g. If I put Length = 100mm then
Part created of 100mm length by using iLogic rule.
When I place this part in assembly it doest not again ask for Length.
"I set user parameter as a Length.
And created simple form.
And only iLogic rule used SHOW FORM."
Message 4 of 8
Please could you post your part?
Message 5 of 8
Its Autodesk Inventor 2014 version file. find attachment.
Message 6 of 8
If you delete the iLogic rule and form in the part, and tick 'Key' next to length, it should behave as you want.
On insert with iLogic, you will be prompted to set the Lenght, but after that - you won't be prompted again.
Message 7 of 8
wacho31
in reply to: ratneshmalik1990
I would like to ask you if you could help me with below issue.
I would like place eg. pipes into my assembly
I set rule in part (pipe) like this:
dlugosc_rury = InputBox("Wprowadź długość rury w mm", "Długość rury", "")
iLogicVb.UpdateWhenDone = True
I would like place it many times to assembly with different length but if i used in assemlby code:
Sub Main()
Dim oAsm As AssemblyDocument = ThisDoc.Document
For Each oRefDoc As Document In oAsm.AllReferencedDocuments
	If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Or oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject AndAlso _
		oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc).Count > 0
		On Error Resume Next
		iLogicVb.Automation.RunRule(oRefDoc, "dlugosc_rury")
Next
End Sub
1. rule run only after component placing (pop up window should be visible before component placing)
2. rule run for all placed pipes (should work separately for each placed parts)
Could you help me with correct code?
thank you
BR
Paweł
Message 8 of 8
wacho31
in reply to: PaulMunford
Sub Main()
Next
End Sub
thank you
BR
Paweł
Technology Administrators
