iLogic rule: Straight VB code
I write my code in visual studio then copy and paste it into an ilogic rule. I typically have some cleanup to do on the code once it's in ilogic. For instance ilogic doesn't accept regions and other things. So I started looking for ways where I can paste without cleanup. I can across the ilogic rule setting "Straight VB code". I can't get it working and the documentation written about it doesn't make sense. Can you explain why my code doesn't work?
Imports System
Imports System.Type
Imports System.Activator
Imports SysInter = System.Runtime.InteropServices
Imports System.IO
Imports Inv = Inventor
Module Module1
'By:
'Date: 10/11/19
Public Sub Main()
	MsgBox("Main")
	GetDoc()
End Sub
#Region "Some Sub to Test"
Public Sub GetDoc()
		If ThisDoc.Document.Type = Inv.DocumentTypeEnum.kAssemblyDocumentObject Then
			MsgBox("Document is an Assembly.")
		Else If ThisDoc.Document.Type = Inv.DocumentTypeEnum.kDrawingDocumentObject Then
			MsgBox("Document is an Drawing.")
		Else If ThisDoc.Document.Type = Inv.DocumentTypeEnum.kPartDocumentObject Then
		Else
			MsgBox("Not a typical document type.")
    End Sub
#End Region
End Module
Hi
Remove the "Module Module1" and the End Module statements.
Pascal
Sergio.D.Suárez
Hi, try the following ilogic rule.
Below in comments mode you have the description of the different types of files.
Public Sub Main()
	MsgBox("Main")
	GetDoc()
End Sub
Public Sub GetDoc()
        Dim doc = ThisDoc.Document
		If doc.DocumentType = 12291 Then MsgBox("Document is an Assembly.")
		If doc.DocumentType = 12294 Then MsgBox("Document is a Design Element Document.")
		If doc.DocumentType = 12292 Then MsgBox("Document is a Drawing Document.")
		If doc.DocumentType = 12295 Then MsgBox("Document is a Foreign Model Document.")
		If doc.DocumentType = 12297 Then MsgBox("Document is a No Document.")
		If doc.DocumentType = 12290 Then MsgBox("Document is a Part Document.")
		If doc.DocumentType = 12293 Then MsgBox("Document is a Presentation Document.")
		If doc.DocumentType = 12296 Then MsgBox("Document is a SAT File Document.")
		If doc.DocumentType = 12289 Then MsgBox("Document is an Unknown Document.")
    End Sub
'kAssemblyDocumentObject 12291 Assembly Document.
'kDesignElementDocumentObject 12294 Design Element Document.
'kDrawingDocumentObject 12292 Drawing Document.
'kForeignModelDocumentObject 12295 Foreign Model Document.
'kNoDocument 12297 No Document.
'kPartDocumentObject 12290 Part Document.
'kPresentationDocumentObject 12293 Presentation Document.
'kSATFileDocumentObject 12296 SAT File Document.
'kUnknownDocumentObject 12289 Unknown Document.
 I hope this helps with your problem, Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
