Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board.
ilogic rule for create .Idw Automation
justin.johnsonQLTK2
justin.johnsonQLTK2
Hi All,
I am working on a new project, so it has more than 500 drawings to create.
Is there any way to create .Idw automatically when we create .ipt or .iam ?
                         or
Is there any ilogic code or tool to create batch .idw from an assembly?
Thanks in advance,
Justin
tyas.swinnen
Hi Justin,
I made a VBA script to iterate through my assemblies and check if they already have a drawing file.
If not, it creates them (and does some extra's).
Here some functions of my script to set you going: (I'm not saying this is the most efficient way to do this, but hey, for now it works :-), feedback always welcome!)
Private Function Excecute(ByVal oDoc As Document, textLocation As String)
        Debug.Print oDoc.FullFileName
        If CheckNaam(oDoc) Then
            Dim drawingFilename As String
                drawingFilename = FindDrawingFile(oDoc)
            Dim tempName As String
                tempName = Right(oDoc.FullFileName, 15)
            Dim saveName As String
                saveName = Left(oDoc.FullFileName, Len(oDoc.FullFileName) - 4) & ".idw"
            If drawingFilename <> "" Then
                Call TextFile(textLocation, "The drawing for """ & tempName & """ was found: " & vbCr & drawingFilename)
                'MsgBox "The drawing for """ & tempName & """ was found: " & vbCr & drawingFilename
            Else
                Dim oNewName As String
                oNewName = oDoc.FullDocumentName
                'Call TextFile(textLocation, "Trying: " & oNewName)
                ThisApplication.SilentOperation = True
                Dim oDrawing As DrawingDocument
                Set oDrawing = ThisApplication.Documents.Add(kDrawingDocumentObject, **insert your desired .idw template location here**, False)
                Call PlaceView(oDrawing, oDoc)
                Select Case oDoc.DocumentType
                    Case DocumentTypeEnum.kAssemblyDocumentObject:
                        'Call to parts list insertion function
                        'Call to correct assy titleblock insertion
                    Case DocumentTypeEnum.kPartDocumentObject:
                    Case Else: Exit Function
                End Select
                'MsgBox saveName
                saveName = Left(oNewName, Len(oNewName) - 4) + ".idw"
                Call oDrawing.SaveAs(saveName, False)
                oDrawing.Close (True)
                'Call TextFile(textLocation, "A drawingdocument was created for '" & saveName & "'")
            End If
        End If
End Function
Private Function PlaceView(ByVal oDrawing As DrawingDocument, oRefDoc As Document)
    Dim oSheet As Sheet
    Set oSheet = oDrawing.ActiveSheet
    Dim oPlacementPoint1 As Point2d
    Dim oPlacementPoint2 As Point2d
    Dim oPlacementPoint3 As Point2d
    Set oPlacementPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(12.5, 20)
    Set oPlacementPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(25, 20)
    Set oPlacementPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(12.5, 10)
    ' Define the view scales that we need.
    Dim ViewScale1 As Double
    If oRefDoc.DocumentType = kPartDocumentObject Then
        ViewScale1 = CalculateScale(getRangeboxLargest(oRefDoc)) '1#
    Else
        ViewScale1 = 1#
    End If
    ' define the view orientation for each view
    Dim ViewOrientation1 As ViewOrientationTypeEnum
        ViewOrientation1 = ViewOrientationTypeEnum.kFrontViewOrientation
    ' define the view style for each view
    Dim ViewStyle1 As DrawingViewStyleEnum
        ViewStyle1 = DrawingViewStyleEnum.kHiddenLineDrawingViewStyle
    ' now create our view
    Dim oView1 As DrawingView
    Dim oView2 As DrawingView
    Dim oView3 As DrawingView
    Set oView1 = oSheet.DrawingViews.AddBaseView(oRefDoc, oPlacementPoint1, ViewScale1, ViewOrientation1, ViewStyle1)
    If Not oView1.ActiveLevelOfDetailRepresentation = "Master" Then
    End If
        Set oView2 = oSheet.DrawingViews.AddProjectedView(oView1, oPlacementPoint2, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
        Set oView3 = oSheet.DrawingViews.AddProjectedView(oView1, oPlacementPoint3, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
    End If
End Function
Public Function FindDrawingFile(PartOrAssemblyDoc As Document)
    Dim FullFileName As String
    FullFileName = PartOrAssemblyDoc.FullFileName
    ' Extract the path from the full filename.
    Dim path As String
    path = Left$(FullFileName, InStrRev(FullFileName, "\"))
    ' Extract the filename from the full filename.
    Dim filename As String
    filename = Right$(FullFileName, Len(FullFileName) - InStrRev(FullFileName, "\"))
    ' Replace the extension with "idw"
    filename = Left$(filename, InStrRev(filename, ".")) & "idw"
    ' Find if the drawing exists.
    drawingFilename = ThisApplication.DesignProjectManager.ResolveFile(path, filename)
    ' Return the result.
        FindDrawingFile = drawingFilename
    Else
        FindDrawingFile = ""
    End If
End Function
justin.johnsonQLTK2
Hi Tyas Swinnen,
Thank you very much for your help. The programme is similar to what I am looking for.  I have tried to run the rule, but I am getting the Sub main () and End Sub error. I try to fix with the help of Google, it didn't work. I can understand it must be a small issue. could you please guide me to fix it?
Thanks in advance,
Justin
My approach was to set up template files and use the replace reference option.
See if this will work for you (with a few tweaks)
tyas.swinnen
Justin,
First of all, my code is suited for VBA, and not iLogic.
If you just have copy-pasted my code in iLogic you will get even more errors after 'fixing' the first one. 🙂
I suggest you read over my used code as a guide to see how I tackled the problem.
Then you can modify it to your needs/use bits and pieces of it so you understand the script you are making.
(You can ignore the 'Textfile' calls because I did not gave you those lines of code.)
justin.johnsonQLTK2
IDW RULE.PNGIDW RULE.PNGERROR IDW RULE.PNGERROR IDW RULE.PNGTEMPLATE LOCATION.PNGTEMPLATE LOCATION.PNG
I am getting the above error, what am I doing wrong here?  Please guide me.
tyas.swinnen
Hi Justin,
Can you step through your code (open vba editor, click in your script and press F8). Can you tell us on what line gives the error?
Can you include the file extension in the template name in your code. (oCopyFiler -> add .idw in the hard coded templatelocation)
