Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic Refresh Parts List Items After BOM Edit
2 REPLIES 2
stuart.lamb
399 Views, 2 Replies
I'm looking to create an iLogic rule which is run from an assembly drawing to sort and re-number the assembly file BOM and then sort the drawing Parts List by Item.
The code below works fine when editing the BOM, however the edits don't seem to propagate to the Parts List while the code is running. If I tab away from the drawing window and then back again, the Parts List Items will then be updated but it will still require a sort.
I have tried saving the assembly and the drawing with no success. Is there a method to refresh the Parts List and pull through changes made to the BOM programmatically?
Thanks all
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oAsm As AssemblyDocument
oAsm = ThisDrawing.ModelDocument
    ' Set a reference to the BOM
    Dim oBOM As BOM
    oBOM = oAsm.ComponentDefinition.BOM
    Dim oPath As String
    oPath = "C:\Temp\BOM Format.xml"
    oBOM.ImportBOMCustomization(oPath)
    ' Set whether first level only or all levels.
    oBOM.StructuredViewFirstLevelOnly = True
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'Set a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
    oBOMView = oBOM.BOMViews.Item("Structured")
'Sort BOM
oBOMView.Sort("Category", True,"File Path",True)
'Renumber BOM
oBOMView.Renumber(1, 1)
oAsm.Save
Dim oPartsList As PartsList oPartsList = oDrawDoc.ActiveSheet.PartsLists.Item(1) Call oPartsList.Sort("ITEM")
2 REPLIES 2
Hi @stuart.lamb
I think if you add this line to the end of your rule it will update the drawing and parts list.
I hope this helps.
Curtis
InventorVb.DocumentUpdate()
Excellent, thank you Curtis.
