hanks @Curtis_Waguespack , always appreciate your input.
I have a product that I would like to show various configs via a form in the main assembly. I find it works faster if I rather set ViewReps instead of LOD's.
I have a rule in the main sub assembly that works fine when that file is opened explicitly. Then the rule in the top assemblies has a line that runs the rule in the sub assembly, but nothing happens.
Rule in Sub Assy:
'define the document
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
'define the VIEW
Dim oVIEW As DesignViewRepresentation
'define the assembly component definition
Dim oACDef As ComponentDefinition
oACDef = oDoc.ComponentDefinition
'look at parameter and set VReps
'Klappe/Standard options
Select Case Parameter("OPTIONEN")
Case ("1. STANDARD")
oVIEW = oACDef.RepresentationsManager. _
DesignViewRepresentations.Item("1. STANDARD").Activate
Case ("2. KLAPPE")
DesignViewRepresentations.Item("2. KLAPPE").Activate
End Select
Rule in Top Assy
'Parameter from Assembly to Sub Components
Parameter("EA2314.010000 ZBG Mäher Grundgehäuse:1", "OPTIONEN") = OPTIONEN
iLogicVb.RunRule("EA2314.010000 ZBG Mäher Grundgehäuse:1", "Konfigurationen")
'Optionen: Standard/Klappe
Component.Visible("EA2314.080000 ZBG Klappe:1") = False
Case ("2. KLAPPE")
Component.Visible("EA2314.080000 ZBG Klappe:1") = True
End Select
'define the VIEW
'look at parameter and toggle visibility components
'Befestigung Options
Select Case Parameter("BEFESTIGUNG")
Case "1. STARR"
'set VRep
DesignViewRepresentations.Item("1. STARR").Activate
Case "2. PRLG"
'set VRep
DesignViewRepresentations.Item("2. PRLG").Activate
Case "3. 3-PUNKT"
'set Vrep
DesignViewRepresentations.Item("3. 3-PUNKT").Activate
Case "4. A-RAHM"
'set Vrep
DesignViewRepresentations.Item("4. A-RAHM").Activate
End Select
It there a way to rather set the sub assy VRep from the top assy rule, instead of having a second rule? Or what is wrong that the sub assy does not adjust when its rule is run from top assy rule?
Any assistance appreciated.
Theo
