iLogic "End of statement expected"
ASchlaack
Message 1 of 12
ASchlaack
I'm trying to use iLogic while making a conveyor rail. If the rail is under 60in, I don't need supports. I keep getting  "End of statement expected" as an error. What am I doing wrong or how should this be phrased other than how I have it?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
Replies (11)
Message 2 of 12
Curtis_Waguespack
Hi ASchlaack,
I think you'll need a space between 60 and in:
60 in
rather than:
60in
I hope this helps.
Curtis
Message 3 of 12
ASchlaack
Thanks, I did that which cleared line one's error BUT still have the ones on line 9. Any other ideas?
Aaron Schlaack
Message 4 of 12
Curtis_Waguespack
Hi ASchlaack,
I think you need an Else If on that line. Try something like this example:
If Parameter("Rail_Length") < 60 in Then
MessageBox.Show("not quite 60", "iLogic")
Else If Parameter("Rail_Length") >= 60 in Then
MessageBox.Show("60 or more", "iLogic")
Else 'this Else is optional
End If
Here is a better example of an Else (without If) in use, in case it helps:
Else If Parameter("Rail_Length") > 60 in Then
MessageBox.Show("over 60", "iLogic")
Else
MessageBox.Show("I guess it must be 60!", "iLogic")
End If
 I hope this helps.
Curtis
Message 5 of 12
ASchlaack
Thank you, I ended up getting it with this (Rule posted below) I also added two other pieces to supress.
I am now getting this error though:
Error in rule: Rule0, in document: Assembly2
Component.IsActive: Cannot change the suppression state of component TEST-Horizontal-FlangeAngleL:3.
The active Level of Detail in Assembly2 is not a custom Level of Detail.
Rule that worked:
If Parameter("TEST8-Horizontal-Rail1201:1", "d19") < 60 in Then
Component.IsActive("TEST-Horizontal-FlangeAngleL:3")=False
Component.IsActive("TEST-Horizontal-FlangeAngleL:4")=False
Component.IsActive("TEST-Horizontal-FlangeAngleR:4")=False
Component.IsActive("TEST-Horizontal-FlangeAngleR:3")=False
Else
Component.IsActive("TEST-Horizontal-FlangeAngleL:3")=True
Component.IsActive("TEST-Horizontal-FlangeAngleL:4")=True
Component.IsActive("TEST-Horizontal-FlangeAngleR:4")=True
Component.IsActive("TEST-Horizontal-FlangeAngleR:3")=True
EndIf
Aaron Schlaack
Message 6 of 12
Curtis_Waguespack
Hi ASchlaack,
So in order to suppress something in Inventor using iLogic you must have a Level of Detail that can be edited, set active in the assembly. Most often we use a snippet of code to look for an existing "iLogicLOD", and then create it, should it not be found. Once the "iLogicLOD" is set active, you can have your rule suppress parts as needed.
Here's a quick example:
'define the document
Dim oDoc as AssemblyDocument
oDoc = ThisDoc.Document
'define the LOD
Dim oLOD As LevelOfDetailRepresentation
'define the assembly component definition
Dim oACDef As ComponentDefinition
oACDef = oDoc.ComponentDefinition
Try
     'try to activate the iLogic LOD
     oLOD = oACDef.RepresentationsManager. _
     LevelOfDetailRepresentations.Item("iLogicLOD").Activate(True)
Catch
     'catch error when iLogic LOD doesn't exist
     'and then create it
     LevelOfDetailRepresentations.Add("iLogicLOD")
     'activate the newly created iLogic LOD
End Try 'look at parameter and suppress components 'if the parameter is less than 60 inches If Parameter("TEST8-Horizontal-Rail1201:1", "d19") < 60 in Then Component.IsActive("TEST-Horizontal-FlangeAngleL:3")=False Component.IsActive("TEST-Horizontal-FlangeAngleL:4")=False Component.IsActive("TEST-Horizontal-FlangeAngleR:4")=False Component.IsActive("TEST-Horizontal-FlangeAngleR:3")=False Else Component.IsActive("TEST-Horizontal-FlangeAngleL:3")=True Component.IsActive("TEST-Horizontal-FlangeAngleL:4")=True Component.IsActive("TEST-Horizontal-FlangeAngleR:4")=True Component.IsActive("TEST-Horizontal-FlangeAngleR:3")=True End If
I hope this helps.
Curtis
Message 7 of 12
ASchlaack
Thank you Curtis!
Aaron Schlaack
Message 8 of 12
tjvz85
Hi @Curtis_Waguespack ,
How would I do the exact same for a DesignViewRepresentation?
I tried to just replace LOD with ViewRep, but get this error. "Public member 'Activate' on type 'DesignViewRepresentation' not found."
Dim oDoc As AssemblyDocument
'define the VIEW
Dim oVIEW As DesignViewRepresentation
Try
     'try to activate the iLogic VIEW
     oVIEW = oACDef.RepresentationsManager. _
     DesignViewRepresentations.Item("iLogicVIEW").Activate(True)
Catch
     'catch error when iLogicVIEW doesn't exist
     'and then create it
     DesignViewRepresentations.Add("iLogicVIEW")
     'activate the newly created iLogicVIEW
End Try
This creates a ViewRep, but does so every time the rule runs, then gives the error.
Regards
Theo
Message 9 of 12
Curtis_Waguespack
Hi @tjvz85 ,
I didn't look to see what the differences between the LOD and VReps were but here is an example that works:
'define the VIEW
Try
Catch
     'and then create it
End Try
I hope this helps.
Curtis
Message 10 of 12
tjvz85
hanks @Curtis_Waguespack , always appreciate your input.
I have a product that I would like to show various configs via a form in the main assembly. I find it works faster if I rather set ViewReps instead of LOD's.
I have a rule in the main sub assembly that works fine when that file is opened explicitly. Then the rule in the top assemblies has a line that runs the rule in the sub assembly, but nothing happens.
Rule in Sub Assy:
'define the VIEW
'look at parameter and set VReps
'Klappe/Standard options
Select Case Parameter("OPTIONEN")
Case ("1. STANDARD")
	DesignViewRepresentations.Item("1. STANDARD").Activate
Case ("2. KLAPPE")
	DesignViewRepresentations.Item("2. KLAPPE").Activate
End Select
Rule in Top Assy
'Parameter from Assembly to Sub Components
Parameter("EA2314.010000  ZBG Mäher Grundgehäuse:1", "OPTIONEN") = OPTIONEN
iLogicVb.RunRule("EA2314.010000  ZBG Mäher Grundgehäuse:1", "Konfigurationen")
'Optionen: Standard/Klappe
	Component.Visible("EA2314.080000  ZBG Klappe:1") = False
Case ("2. KLAPPE")
	Component.Visible("EA2314.080000  ZBG Klappe:1") = True
End Select
'define the VIEW
'look at parameter and toggle visibility components
'Befestigung Options
Select Case Parameter("BEFESTIGUNG")
Case "1. STARR"
'set VRep
	DesignViewRepresentations.Item("1. STARR").Activate
Case "2. PRLG"
'set VRep
	DesignViewRepresentations.Item("2. PRLG").Activate
Case "3. 3-PUNKT"
'set Vrep
	DesignViewRepresentations.Item("3. 3-PUNKT").Activate
Case "4. A-RAHM"
'set Vrep
	DesignViewRepresentations.Item("4. A-RAHM").Activate
End Select
It there a way to rather set the sub assy VRep from the top assy rule, instead of having a second rule? Or what is wrong that the sub assy does not adjust when its rule is run from top assy rule?
Any assistance appreciated.
Theo
Message 11 of 12
Curtis_Waguespack
Hi @tjvz85
I think this will answer your questions, post back if not.
I hope this helps.
Curtis
oViewName = "iLogicVIEW"
'get the subassembly component occurence
Dim oOcc = Component.InventorComponent("Test1:1")
oACDef = oOcc.Definition.Document.ComponentDefinition
Try
     'Try To get the iLogic View
     DesignViewRepresentations.Item(oViewName)
Catch
     'and then create it
     DesignViewRepresentations.Add(oViewName)
End Try
'activate it
oOcc.SetDesignViewRepresentation(oViewName,, True)
Message 12 of 12
tjvz85
Works like a charm
Dim oOcc = Component.InventorComponent("EA2314.010000 ZBG Mäher Grundgehäuse:1")
Dim oOCDef As ComponentDefinition
oOCDef = oOcc.Definition.Document.ComponentDefinition
'Parameter in top level, chain or klappe
'activate vrep in sub assembly
oOcc.SetDesignViewRepresentation("1. STANDARD", , True)
Case ("2. KLAPPE")
oOcc.SetDesignViewRepresentation("2. KLAPPE", , True)
End Select
