iLogic partslist expand children
Hello. I was wondering if anyone could help me with this.
Below is the code I use to create an .IDW, create a partslist and export the partslist as EXCEL.
I need to know if I can expand all children before exporting it.
SyntaxEditor Code Snippet
v_RutaYNombre= ThisDoc.PathAndFileName(False)
Dim v_DocReferencia As Document = ThisApplication.ActiveDocument
Dim v_Plano As DrawingDocument = ThisApplication.Documents.Add(kDrawingDocumentObject, "V:\Templates\Templates 2017\INOXPASER\INOXPASER MECANIZADO ISO2768m2017.idw", True)
Dim v_Hoja As Sheet = v_Plano.ActiveSheet
Dim v_GeoTrans As TransientGeometry = ThisApplication.TransientGeometry
v_Opciones = ThisApplication.TransientObjects.CreateNameValueMap
v_ManagerEstilos = v_Plano.StylesManager
v_EstiloLista = v_ManagerEstilos.PartsListStyles.Item("BOM")
v_Plano = ThisApplication.ActiveDocument
v_Plano.SaveAs(v_RutaYNombre & "BOM.idw",False)
v_VistaSuperior = v_Hoja.DrawingViews.AddBaseView(v_DocReferencia,v_GeoTrans.CreatePoint2d(-15,0 ),.25,ViewOrientationTypeEnum.kTopViewOrientation,DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle,,,)
v_Marco= v_Hoja.Border
v_ListaPiezas = v_Hoja.PartsLists.Add(v_VistaSuperior, v_Marco.RangeBox.MaxPoint,PartsListLevelEnum.kStructuredAllLevels)
v_Hoja.PartsLists(1).Style = v_EstiloLista
v_Opciones.Value("AutoFitColumnWidth") = True
v_ListaPiezas.Export(ThisDoc.Path & "\BOM.xls", PartsListFileFormatEnum.kMicrosoftExcel,v_Opciones)
v_Plano.Close
My.Computer.FileSystem.DeleteFile(v_RutaYNombre & "BOM.idw")
I'm posting 2 images:
1 As the partslist comes with my code
1 As it should be (with all levels expanded)
Thanks in advance!
clutsa
Here's a sample of what you could do.
Dim app As Inventor.Application = ThisApplication
Dim doc As DrawingDocument = app.ActiveDocument
Dim oSheet As Sheet = doc.ActiveSheet
Dim partslist As PartsList = oSheet.PartsLists(1)
Dim oRow As PartsListRow
Dim FirstRowCount As Integer = partslist.PartsListRows.Count
Dim LastRowCount As Integer = 0
Do Until FirstRowCount = LastRowCount
	FirstRowCount = partslist.PartsListRows.Count
	For Each oRow In partslist.PartsListRows
		Try
			oRow.Expanded = True
		Catch ex As Exception
		End Try
	Next
	LastRowCount = partslist.PartsListRows.Count
Loop
I know you have parts of my code already in your code but you get the idea.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Thanks man!!
Works like a charm.
dominiek_vanwest
The code from @clutsa works but if you have a big partslist it can take a while.
I've tried with my code below, which works a bit faster (as it goes through each line of the partslist only once).
Dim oPartsList As PartsList = oSheet.PartsLists(1)
Dim i As Integer
Do Until i = oPartsList.PartsListRows.Count + 1
    On Error Resume Next
    oPartsList.PartsListRows(i).Expanded = True
    i = i + 1
Loop
However, it still doesn't work fast enough.
I have a partslist with 470 rows and my code takes about 1min15s to execute.
If I would do it manually (open partslist -> select column +/- -> right click -> Expand All Children) it takes only 5-10s.
Is there a way to improve speed of this?
I've also tried with Defer Updates and turn off visibility of Inventor but those didn't help.
Thanks in advance,
Dominiek
Jacob__with__a__k
just here to pitch my version of this solution:
same idea but it avoids throwing and catching a bunch of errors if the rows cannot be expanded
also a failsafe because I will never ever trust loops
and a bit of logging for testing
'expand all
Dim i As Integer = 0
Dim count As Integer = oPartslist.PartsListRows.Count
Do
    i = i + 1
    Try
    	If oPartslist.PartsListRows(i).Expandable
			If Not oPartslist.PartsListRows(i).Expanded
				oPartslist.PartsListRows(i).Expanded = True
				Logger.Trace("row" & i & " (of " & count & ") expanded")
			Else
				Logger.Trace("row" & i & " (of " & count & ") already expanded")
			End If
			count = oPartslist.PartsListRows.Count
		Else
			Logger.Trace("row" & i & " (of " & count & ") part")
		End If
	Catch
		Logger.Trace("row" & i & " (of " & count & ") error")
	End Try
	If i > 500
		Logger.Error("loop expand partslist stopped (" & iLogicVb.RuleName & " in " & ThisDoc.Document.DisplayName & ")")
		Exit Do
	End If
Loop While i <= count
so yes, a bit more code but it's more stable and faster so worth it
this took 3 seconds for a parts list of 142 rows (expanded) with 12 assemblies that needed to be expanded
Happy coding!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
