So I am trying to run a loop on all components in assembly and save part extent details to its iproperties. But ilogic function "Measure" doesn't work as it's capturing details of open assembly instead of part that I've opened. Also when I save iproperties, it's getting saved in assembly file instead of opened part doc. I think I am missing something major about how iLogic scope works.
Any solution?
Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments Dim oRefDoc As Document 'work the the drawing files for the referenced models 'this expects that the model has been saved For Each oRefDoc In oRefDocs iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt" 'check that model is saved If(System.IO.File.Exists(iptPathName)) Then Dim oDrawDoc As PartDocument oDrawDoc = ThisApplication.Documents.Open(iptPathName, True) Try ' TODO: measure dimensions of opened part Dim x = Measure.ExtentsLength Dim y = Measure.ExtentsWidth Dim z = Measure.ExtentsHeight Dim Thick = MinOfMany (x, y, z) Dim Length = MaxOfMany (x, y, z) Dim Width = x + y + z - Thick - Length ' TODO: Write to open document iProperties.Value("Custom", "THICKNESS")= Thick iProperties.Value("Custom", "WIDTH")= Width iProperties.Value("Custom", "LENGTH")= Length iProperties.Value("Custom", "RM Type") = "Plate" oDrawDoc.Save Catch End Try oDrawDoc.Close Else End If Next
Solved by Sergio.D.Suárez. Go to Solution.
I've figured out editing iproperties part like this, still need to get Measure function to work on opened document:
' DONE: Edit properties of opened file Dim oSubPropSet As PropertySet oSubPropSet = oDrawDoc.PropertySets.Item("User Defined Properties") oSubPropSet.Add(Thick, "THICKNESS") oSubPropSet.Add(Width, "WIDTH") oSubPropSet.Add(Length, "LENGTH") oSubPropSet.Add("Plate", "RM Type") oDrawDoc.Save
Hi, here is a code that adds the measures to the parties I have not checked it well, but I think it should work well. Add the line to skip the assembly document, so do not place the measurements in this type of file.
Dim oAsmDoc As AssemblyDocument= ThisDoc.Document For Each oRefDoc As Document In oAsmDoc.AllReferencedDocuments If oRefDoc.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then customPropertySet = oRefDoc.PropertySets.Item("Inventor User Defined Properties") Dim oX As Double = 0 Dim oY As Double = 0 Dim oZ As Double = 0 For Each oBody As SurfaceBody In oRefDoc.ComponentDefinition.SurfaceBodies oBodyX = Round(oBody.RangeBox.MaxPoint.X - oBody.RangeBox.MinPoint.X, 2) oBodyY = Round(oBody.RangeBox.MaxPoint.Y - oBody.RangeBox.MinPoint.Y, 2) oBodyZ = Round(oBody.RangeBox.MaxPoint.Z - oBody.RangeBox.MinPoint.Z, 2) If oBodyX > oX Then oX = oBodyX If oBodyY > oY Then oY = oBodyY If oBodyZ > oZ Then oZ = oBodyZ Next Dim Thick = MinOfMany (oX, oY, oZ) Dim Length = MaxOfMany (oX, oY, oZ) Dim Width = oX + oY + oZ - Thick - Length ' Write to open document Try customPropertySet.Item("THICKNESS").Value = Thick * 10 & " mm" Catch customPropertySet.Add("", "THICKNESS") customPropertySet.Item("THICKNESS").Value = Thick * 10 & " mm" End Try Try customPropertySet.Item("WIDTH").Value = Width * 10 & " mm" Catch customPropertySet.Add("", "WIDTH") customPropertySet.Item("WIDTH").Value = Width * 10 & " mm" End Try Try customPropertySet.Item("LENGTH").Value = Length * 10 & " mm" Catch customPropertySet.Add("", "LENGTH") customPropertySet.Item("LENGTH").Value = Length * 10 & " mm" End Try oRefDoc.Save End If Next
I hope it is useful. regards
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
