iLogic LOD BOM question
- Mute
- Permalink
- Report
Why do I have to save every time when a LOD (iLogic) is active to get the BOM? even if only the position of one part changes a bit.
You can see this by: open a new Assembly, create a new part, (draw a block) create a new LOD (f.e. iLogic)
when you are in the master LOD you can alway get the BOM.
when the iLogic LOD is active, you first have to save to get the BOM. when you move the part only a tiny bit, you will have to save the assembly first to get the BOM... WHY??? nothing changed in regarding to the BOM? or is there something I don't see?
I ask this question because our Assembly that we want to configurate through iLogic is very big, so it take some time evrey save. And even at one point we could not open the BOM because we had to save it first, and after the save the BOM still did not work because it prompted to save the assembly first.
what can be done about this? is there maybe a different workflow?
thanks
Henk
Kudo's are also appreciated
Succes on your project, and have a nice day
Herm Jan
