I have an iLogic code that I've pieced together from various snippets I've found on the forums. It works fairly well except for the file name. We use this code to pull all sheet metal parts from an assembly, create a dxf of the flat pattern, and place in a specific folder. We then run a second rule to create an excel spread sheet that is a custom filtered BOM of just sheet metal components, revision level, material, etc. For example, if I have a part number 1111-222 revision A, I want the file to export as 1111-222_RevA.dxf
On Occasion, the revision level will be missing. It will be 1111-222Rev.dxf It seems to happen very sporadically and I have not been able to nail down why that might be.
Any suggestions I am an open book, thank you!
Code:
'EXPORT DXF TO FOLDER CHOSEN'define the active document as an assembly file Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) 'check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If 'get user input RUsure = MessageBox.Show ( _ "This will create a DXF file for all of the asembly components that are sheet metal." _ & vbLf & "This rule expects that the part file is saved." _ & vbLf & " " _ & vbLf & "Are you sure you want to create DXF for all of the assembly components?" _ & vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo) If RUsure = vbNo Then Return Else End If oPath = ThisDoc.Path oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap 'get DXF target folder path oFolder1 = "O:\Engineering\Print Request Files\Data Packet Folders\" Shell("explorer.exe " + oFolder1, vbNormalFocus) RFQEntry : Dim sRFQNumber As String = InputBox("DP Number:", "DATA PACKET NUMBER ENTRY",) If Len(sRFQNumber) <> 4 Then MessageBox.Show("DP Number must be 4 numbers i.e. 1234 to continue.") Goto RFQEntry End If oFolder = "O:\Engineering\Print Request Files\Data Packet Folders\" + sRFQNumber 'Check for the DXF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - -'- - - - - - - - - - - - -Component - - - - - - - - - - - -'look at the files referenced by the assembly Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments Dim oRefDoc As Document 'work the the drawing files for the referenced models'this expects that the model has been saved For Each oRefDoc In oRefDocs iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt" Dim Rev As String = iProperties.Value(FName, "Project", "Revision Number") If(System.IO.File.Exists(iptPathName)) Then Dim oDrawDoc As PartDocument oDrawDoc = ThisApplication.Documents.Open(iptPathName, True) oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName)) Try 'Set the DXF target file name Try CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR") Catch CustomName ="" End Try oDataMedium.FileName = oFolder & "\" & CustomName & " " & oFileName & "_Rev" & Rev & ".dxf" Dim oCompDef As SheetMetalComponentDefinition oCompDef = oDrawDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold Else oCompDef.FlatPattern.Edit End If Dim sOut As String sOut = "FLAT PATTERN DXF?AcadVersion=2004&RebaseGeometry=True&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_ARC_CENTERS;IV_TANGENT;IV_ROLL;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_FEATURE_PROFILES_DOWN;IV_FEATURE_PROFILES;IV_TOOL_CENTER_DOWN;DIGI_MARKER_TOOL_1;DIGI_MARKER_TOOL_2;IV_BEND;IV_BEND_DOWN;IV_INNER_PROFILES;" oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName) oCompDef.FlatPattern.ExitEdit Catch End Try oDrawDoc.Close Else End If Next
Solved by ibraunLEW5D. Go to Solution.
Solved by JhoelForshav. Go to Solution.
Hi @ibraunLEW5D
Looking through your code, I see that you're using a variable "FName" when getting the revision number. This variable is never declared before in the code so that is just Nothing.
The iLogic functionality you're using will return the assemblys revision number in the case of that agument being nothing. So when you get a revision number, it's because the assembly has one and it's the assemblys number you'll get.
Since you're already looping through the document objects I'd suggest using those to retrieve their revision numbers.
See my minor change to the code below. I think it's what you need 🙂
'EXPORT DXF TO FOLDER CHOSEN'define the active document as an assembly file Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) 'check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If 'get user input RUsure = MessageBox.Show ( _ "This will create a DXF file for all of the asembly components that are sheet metal." _ & vbLf & "This rule expects that the part file is saved." _ & vbLf & " " _ & vbLf & "Are you sure you want to create DXF for all of the assembly components?" _ & vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo) If RUsure = vbNo Then Return Else End If oPath = ThisDoc.Path oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap 'get DXF target folder path oFolder1 = "O:\Engineering\Print Request Files\Data Packet Folders\" Shell("explorer.exe " + oFolder1, vbNormalFocus) RFQEntry : Dim sRFQNumber As String = InputBox("DP Number:", "DATA PACKET NUMBER ENTRY",) If Len(sRFQNumber) <> 4 Then MessageBox.Show("DP Number must be 4 numbers i.e. 1234 to continue.") GoTo RFQEntry End If oFolder = "O:\Engineering\Print Request Files\Data Packet Folders\" + sRFQNumber 'Check for the DXF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - -'- - - - - - - - - - - - -Component - - - - - - - - - - - -'look at the files referenced by the assembly Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments Dim oRefDoc As Document 'work the the drawing files for the referenced models'this expects that the model has been saved For Each oRefDoc In oRefDocs iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt" 'Dim Rev As String = iProperties.Value(FName, "Project", "Revision Number") 'FName doesn't exist Dim Rev As String = oRefDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value If(System.IO.File.Exists(iptPathName)) Then Dim oDrawDoc As PartDocument oDrawDoc = ThisApplication.Documents.Open(iptPathName, True) oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName)) Try 'Set the DXF target file name Try CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR") Catch CustomName ="" End Try oDataMedium.FileName = oFolder & "\" & CustomName & " " & oFileName & "_Rev" & Rev & ".dxf" Dim oCompDef As SheetMetalComponentDefinition oCompDef = oDrawDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold Else oCompDef.FlatPattern.Edit End If Dim sOut As String sOut = "FLAT PATTERN DXF?AcadVersion=2004&RebaseGeometry=True&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_ARC_CENTERS;IV_TANGENT;IV_ROLL;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_FEATURE_PROFILES_DOWN;IV_FEATURE_PROFILES;IV_TOOL_CENTER_DOWN;DIGI_MARKER_TOOL_1;DIGI_MARKER_TOOL_2;IV_BEND;IV_BEND_DOWN;IV_INNER_PROFILES;" oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName) oCompDef.FlatPattern.ExitEdit Catch End Try oDrawDoc.Close Else End If Next
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
Wow thank you! This works perfect now. I knew it would be simple, I just didn't know it would be quite that simple.
