Ilogic for summy up selected Ipropeties parts
4 REPLIES 4
schmidkeadam
515 Views, 4 Replies
Hi everyone,
I'm not the best at illogic (still learning it) and i seem to have stumped myself. I have written code to be able to select multiple parts and show an iproperties in a single message box but that not quite what I am looking for, What  I am looking for is to be able to sum an iproperties and display the total in a message box. I have spent a lot of time trying to modify what I have got but with no luck. what would be the best way of handling this?
My code:
Dim oOccurrence As ComponentOccurrence
Dim Prop As String
Dim messageText As String
Try
   oOccurrence = ThisDoc.Document.SelectSet.Item(1)
Catch
   MessageBox.Show("Please select a component(s) before running this rule.", "iLogic")
   Return
End Try
For Each oOccurrence In ThisDoc.Document.SelectSet
   If TypeOf oOccurrence Is ComponentOccurrenceProxy Then
       Cost = iProperties.Value(oOccurrence.NativeObject.Name, "Project", "Estimated Cost")
   Else
               Cost = iProperties.Value(oOccurrence.Name, "Project", "Estimated Cost")
   End If
   messageText = messageText &
        "Cost = " & Cost
Next
MessageBox.Show(messageText, "Summary")
4 REPLIES 4
Lewis.Young
in reply to: schmidkeadam
SyntaxEditor Code Snippet
Sub Main TraverseAssemblySample()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    Dim oCost As Decimal
    oCost = 0
    Try
           oOcc = ThisDoc.Document.SelectSet.Item(1)
    Catch
    Return
    End Try
    ' Call the function that does the recursion.
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, oCost)
    MessageBox.Show(" & oCost, "Total Cost")
End Sub
Private Sub TraverseAssembly(ByVal Occurrences As ComponentOccurrences, _
                             ByVal Level As Integer, _
                             ByRef oCost As Double)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
Dim oOcc As ComponentOccurrence
Dim Prop As String
'Try
'   oOcc = ThisDoc.Document.SelectSet.Item(1)
'Catch
'   MessageBox.Show("Please select a component(s) before running this rule.", "iLogic")
'Return
'End Try
For Each oOcc In ThisDoc.Document.SelectSet
    'For Each oOcc As ComponentOccurrence In Occurrences
        ' Skip Phantom and reference parts.
        If oOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure _
        Or oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
                        ' Do Nothing
                Else
                ' The occurrence is valid count the cost.
                ' Get the document file for this occurrence
                Dim oDoc As Document
                oDoc = oOcc.Definition.Document
                ' Get the iPropertySet that constains the estimated cost property
                Dim oPropSet As PropertySet
                oPropSet = oDoc.PropertySets.Item("Design Tracking Properties")
                ' Get the cost of this occurrence
                oCost += oPropSet.Item("Cost").Value
         End If
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1, oCost)
        End If
    Next
End Sub
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
schmidkeadam
in reply to: Lewis.Young
Thanks Lewis, thanks for the reply, I think I'm doing something wrong. Every time I us the code you sent, my inventor crashes and doesn't complete the rule. Did it work for you? (this could totally be fault)
Lewis.Young
Try this code instead:
Sub Main
    '- - - - - - - - - - - sum the custom iProperty - - - - - - - - - -
    'clear the custom property in the assembly
    iProperties.Value("Project", "estimated cost") = 0
    'set a reference to the assembly component definintion.
    'This assumes an assembly document is open.
    Dim oAsmCompDef As AssemblyComponentDefinition
    oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    'Iterate through all of the occurrences
    For Each oOccurrence In oAsmCompDef.Occurrences
        Call ProcessAllChildren(oOccurrence)
    Next
    MessageBox.Show("Setting Estimated cost for top level assembly to: " & " & sumNumber, "Estimated cost")
    iProperties.Value("Project", "estimated cost") = Round (sumNumber,2)
End Sub
'Global
Private sumNumber As Double = 0
Public Sub ProcessAllChildren(ByRef oOccurrence As ComponentOccurrence)
      If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
        'property in the parts
        yNumber = iProperties.Value(oOccurrence.Name, "Project", "estimated cost")
        'MessageBox.Show("yNumber =  " & yNumber, oOccurrence.Name)
        sumNumber = sumNumber + yNumber
        'MessageBox.Show("sumNumber =  " & sumNumber,"Running Total")
    Else
        'MessageBox.Show("This is a VirtualComponentDefinition",  oOccurrence.Name)
    End If
    Dim oCompOcc As ComponentOccurrence
    Dim oComponentSubOccurrences As ComponentOccurrences
    For Each oCompOcc In oOccurrence.SubOccurrences
        If oCompOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
           oComponentSubOccurrences = oCompOcc.SubOccurrences
           If Not oComponentSubOccurrences Is Nothing Then
            If oComponentSubOccurrences.count > 0 Then
                ProcessAllChildren(oCompOcc)
            End If
           End If
        Else
        End If
     Next
End Sub
Lewis Young
Vault Basic 2017
3ds Max 2018
schmidkeadam
That worked. Thanks a ton
Technology Administrators
