iLogic FOR loop to unsupress features
13 REPLIES 13
Message 1 of 14
9007 Views, 13 Replies
Hi, I am currently designing a heat exchanger and want to adjust the number of water channel using iLogic. The number of channels to be active is based on the channel dimensions, and is calculated in my excel spreadsheet, but up to a maximum of 19. This is stored in the parameter "no_channel". Each channel is a seperate feature (extrusion) and named from "Channel 1" though "Channel 19".
My idea of doing this automation was to have iLogic suppress all the features, and then doing a closed loop to unsuppres the features I want active:
Feature.IsActive("Channel 1") = False
Feature.IsActive("Channel 2") = False
Feature.IsActive("Channel 19") = False
For i = 1 To no_channel
Feature.IsActive("Channel"(i)) = True
Next
However, this gives me the following error:
Error in rule: Number of channels, in document: Radiator fin side.ipt
Feature.IsActive: No feature found with the name: "h".
I am not experienced with iLogic at all, so any help as well as suggestions on improving the efficieny of my automation would be appreciated (eg. having all features active and simply suppressing the unwanted channels).
Best regards
13 REPLIES 13
Message 2 of 14
Try this. When i = 1, "Channel "& i returns "Channel 1"
Feature.IsActive("Channel "& i) = True
Message 3 of 14
Awesome, that did it!
Thanks a lot.
Message 4 of 14
thank you Jianbinlin  for this great tip, i have also a question!
what if we have 2 identifiers in the  name for example if the name of component is like this " Solid:3-2"  and we have tow variables like "i" and "j" and we would like to change the components state within tow "for" loops ???
the code below did not worked with this configuration because inventor considers "dash" as subtraction sign. i have also tried to change dash sign to UnderLine but not worked. in this case aslo, "i_j" was not correct expression.
so... how should i write this code??
for i=1 to 5
for j=2 to 3
Component.IsActive("Solid:"& i-j) = False
next
next
Regards
Reza
Message 5 of 14
Try this 🙂
For i = 1 to 5
    For j = 2 to 3
        Component.IsActive("Solid:"& i & "-" & j) = False
    Next
Next
This should resolve from
Solid:1-2
to
Solid:5-3
Message 6 of 14
forbillian
I am trying to search for a method to isolate/split common text/prefix instead of an index value, from a feature name so I can suppress
all features with that same prefix text. See below.
Feature Names e.g's:
"PREFIX SOMETHIING"
"PREFIX SOMETHING ELSE"
"PREFIX SOMETHING ELSE AGAIN"
"EXTRUDE1"
"EXTRUDE2"
SyntaxEditor Code Snippet
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oFeatures As PartFeatures
oFeatures = oDoc.ComponentDefinition.Features
Dim oFeature As PartFeature
For Each oFeature In oFeatures
    If oFeature.Name.Contains("PREFIX") Then
       Feature.IsActive("not sure what to put in here?") = False
    End If
Next
I can't seem to manipulate the "Feature.IsActive()" syntax to apply to only the features that contain the text "PREFIX"?
Any help would be greatly appreciated.
Message 7 of 14
in reply to: forbillian
on my opinion, if your "if" statement is true programmatically, you do not need to place any especial command there. and it will be executed as well. but actually I am not sure that the below snippet is true or not.
Message 8 of 14
forbillian
Thanks for the quick response Reza!
The Feature.Name.Contains("PREFIX") is a simpler method of extracting the common text which
appears in the Features I want to isolate and suppress. The other method is using the trim function: Left( Feature.Name,6) = "PREFIX"
BUT...................YES you are absolutely right, I don't need that condition to then suppress a named feature.
But I do want to achieve the same name split of the text as I have done in the ABOVE EXAMPLE
but using this code snippet "Feature.IsActive("featurename") = False" to get my result.
I somehow need the ("featurename") in the above snippet to represent any feature.name that contains the text "PREFIX".
Apologies if I am not explaining it well, but I am simply trying to avoid having to
specify every feature name in full that I want to toggle the suppression on
E.g.
Feature.IsActive("PREFIX - FEATURE SIDE") = False"
Feature.IsActive("PREFIX - FEATURE TOP") = False"
Feature.IsActive("PREFIX - FEATURE RHS") = False"
Feature.IsActive("PREFIX - FEATURE LHS") = False"
Hope this clarifies what I am trying to achieve.
Message 9 of 14
Hi, if you can send me the inventor part I will have a look
Message 10 of 14
Message 11 of 14
forbillian
Find attached a part with Rule example that suppresses Features when each name is specified.
I believe you understand what I am trying to achieve.
Thanks in advance for your time on this. Much appreciated.
Cheers
Forbillian
Message 12 of 14
forbillian
Hey Robert.
I found a solution based on this code I found in an article titled:        'Suppressing all chamfer or fillets with iLogic' By Xiaodong Liang
http://adndevblog.typepad.com/manufacturing/2014/03/subspressing-all-chamfer-or-fillets-with-ilogic....
doc = ThisDoc.Document
oDef = doc.ComponentDefinition
Dim oEachF As PartFeature
For Each oEachF In oDef.Features
    If oEachF.Name.Contains("PREFIX") Then
        oEachF.Suppressed = True
    End If
Next
  See attached part which shows the example & includes another option of text within a different feature name.
Just want to shout out my appreciation to Robertlee Wheatley for your rapid responses and your time and inspiring me
to find a solution.  If you have any other suggestions on this scenario please feel free to let us know.
Message 13 of 14
balkeev.tim
and how to do the same but from the assembly
Message 14 of 14
Hi @balkeev.tim
See this example.
I hope this helps.
Curtis
' Get the active document.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	oDoc = oOccurrence.Definition.Document
	oDef = oDoc.ComponentDefinition
		If oEachF.Name.Contains("Fillet") Then
		End If
	Next
Next
Technology Administrators
