Hello, Is something like this possible through iLogic? Does anyone have an idea how to do this?
Running iLogic in a drawing.
myparam = InputBox("Write the number of the position/baloon you are looking for", "Find baloon and zoom contains number Inputbox", "Default Entry") MessageBox.Show("All sheets contain only =x= occurrences of the searched number of the given balloon." & vbLf & "The active sheet contains =x= searched balloons.", "Title") 'It always starts searching on the active sheet and then continues to other views or other sheets. It switches to the given sheet and zooms in on the balloon number you are looking for. 'If it contains only one baloon of the searched number, then the Msg box will not be displayed. The msg box with the option to continue is displayed only if there are more than one. MessageBox.Show("Do you want to continue to the next balloon occurrence?", "Title",MessageBoxButtons.YesNo)
Solved by JelteDeJong. Go to Solution.
try something like this:
Sub Main()
Dim itemNr As String = InputBox(
"Find baloon and zoom contains number Inputbox", "")
Dim doc As DrawingDocument = ThisDoc.Document
Dim activeSheet As Sheet = doc.ActiveSheet
If (SearchBaolloon(activeSheet, itemNr)) Then Exit Sub
For Each sheet As Sheet In doc.Sheets
If (Sheet Is activeSheet) Then Continue For
Next
End Sub
Public Function SearchBaolloon(sheet As Sheet, itemNr As String)
For Each balloon As Balloon In sheet.Balloons
If (Balloon.BalloonValueSets.Item(1).ItemNumber = itemNr) Then
Dim p = Balloon.Position
Dim target = ThisApplication.TransientGeometry.CreatePoint(p.X, p.Y, 0)
Dim eye = ThisApplication.TransientGeometry.CreatePoint(p.X, p.Y, 100)
Dim diameter = Balloon.Style.BalloonDiameter
' looking at a full size baloon is no fun. Therefore we zoom out a bit
diameter = diameter * 7.5
Dim camera As Camera = ThisApplication.ActiveView.Camera
camera.Target = target
camera.Eye = eye
camera.SetExtents(diameter, diameter)
camera.Apply()
Dim result = MessageBox.Show(
"Title", MessageBoxButtons.YesNo)
If (result = DialogResult.No) Then
Return True
End If
End If
Next
Return False
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you very much. This is incredible. It's amazing. I didn't think such a thing was possible.
According to the picture. I tried to find Baloon/Item 3 and nothing happened. Is there a trick to it?
I did not think of testing the attached balloons. But with a small adjustment, I can solve that. Have a look at his code:
Sub Main()
Next
End Sub
For Each valueSet As BalloonValueSet In Balloon.BalloonValueSets
If (valueSet.ItemNumber = itemNr) Then
ZoomToBalloon(Balloon)
Return True
End If
End If
Next
Next
Return False
End Function
Public Sub ZoomToBalloon(balloon As Balloon)
Dim p = balloon.Position
Dim diameter = balloon.Style.BalloonDiameter
camera.Eye = eye
camera.Apply()
End Sub
Jelte de Jong
Hi.
Really nice piece of iLogic, will come to good use.
I got a code to locate on what view and sheet a balloon is located.
Only thing is that it won't locate balloons that are in a group.
You perhaps got a fix for that?
Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet. Dim oActiveSheet As Sheet oActiveSheet = oDrawDoc.ActiveSheet Dim oBalloon As Balloon Dim oBalloonValueSet As BalloonValueSet Dim oSheet As Sheet For Each oSheet In oDrawDoc.Sheets If oMesssage = "" Then oMesssage = oSheet.Name Else oMesssage = oMesssage & vbLf & oSheet.Name End If oSheet.Activate For Each oBalloon In oDrawDoc.ActiveSheet.Balloons oViewName = oBalloon.ParentView.Name oItem = oBalloon.BalloonValueSets.Item(1).Value oMesssage = oMesssage & vbLf & "Balloon # " & oItem & " is on " & oViewName Next oMesssage = oMesssage & vbLf & "___________________" Next oActiveSheet.Activate 'return to original sheet MessageBox.Show(oMesssage, "iLogic")
I modified the code a bit.
Do you mean something like that?
Class ThisRule Dim moje As Integer = 1 Sub main ' MessageBox.Show("zacatek" & moje, "Title") ' Dim itemNr As String = InputBox( ' "Write the number of the position/baloon you are looking for", ' "Find baloon and zoom contains number Inputbox", "") Dim itemNr As String = InputBox( "CZ = Napište číslo pozice, které hledáte" & vbLf & "EN = Write the position number you are looking for", "Umístění Pozice na všech listech/Show location Baloon in All Sheets") If itemNr = "" Then MessageBox.Show("CZ = Příkaz ukončen" & vbLf & "EN = The command ended.", "Ukončení příkazu") Return 'exit rule End If Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet. Dim oActiveSheet As Sheet oActiveSheet = oDrawDoc.ActiveSheet Dim oBalloon As Balloon Dim oBalloonValueSet As BalloonValueSet Dim oSheet As Sheet For Each oSheet In oDrawDoc.Sheets oSheet.Activate ' MessageBox.Show("pp" & moje, "Title") If moje = 2 Then Exit For Exit Sub Else ' MessageBox.Show("funkce" & moje, "Title") SearchBaolloon(oSheet, itemNr) End If If moje = 2 Then Exit For Next If moje = 2 Then Exit Sub oActiveSheet.Activate 'return to original sheet End Sub Public Sub SearchBaolloon(sheet As Sheet, itemNr As String) ' For Each balloon As Balloon In Sheet.Balloons ' If (Balloon.BalloonValueSets.Item(1).ItemNumber = itemNr) Then For Each balloon As Balloon In sheet.Balloons For Each valueSet As BalloonValueSet In Balloon.BalloonValueSets If (valueSet.ItemNumber = itemNr) Then Dim p = Balloon.Position Dim target = ThisApplication.TransientGeometry.CreatePoint(p.X, p.Y, 0) Dim eye = ThisApplication.TransientGeometry.CreatePoint(p.X, p.Y, 100) Dim diameter = Balloon.Style.BalloonDiameter ' looking at a full size baloon is no fun. Therefore we zoom out a bit diameter = diameter * 7.5 Dim camera As Camera = ThisApplication.ActiveView.Camera camera.Target = target camera.Eye = eye camera.SetExtents(diameter, diameter) camera.Apply() Dim result = MessageBox.Show( "CZ = Chcete pokračovat k dalšímu výskytu pozice?" & vbLf & "EN = Do you want to continue to the next balloon occurrence?", "Pokračuj na další pozici/Continue next Baloon", MessageBoxButtons.YesNo) If (result = DialogResult.No) Then moje = 2 MessageBox.Show("CZ = Příkaz ukončen" & vbLf & "EN = The command ended.", "Ukončení příkazu") ' MessageBox.Show("Ne" & moje, "Title") Exit For Exit Sub Else moje = 1 End If End If If moje = 2 Then Exit For Next If moje = 2 Then Exit For ' If moje = 2 Then Exit Sub'Function ' Return Nothing'Return False Next End Sub End Class
Hi.
No.
Want the ballons that are connected to the first ballonon the view to show up in the list as well.
Now, it only shows the first ballon, in the case above, item 19, 22 & 22 (Again) in View B, but the other ballons don't show up.
